My shop build
/ My shop build
Is this a complete kit you ordered ? If so who did you purchase it from ? I am in the planning stages for a 40x60x16 barn. Your project looks very nice !!!!
Yes, I got it from Mueller. They were super easy to deal with and the price was fair.
/ My shop build
I decided to go ahead and start today. The weather was nice and the concrete is curing well. I was very happy with progress we made today, a neighbor helped for 1/2 the day and I worked alone or with my wife for the other 1/2. He helped with the rafters, which was huge, the other bay has the roll up doors so it's all framed in smaller material and I can do it alone if needed.
Setting the first column by myself.
Our progress today, the forklift doesn't quite reach to the peak so we stacked up some pallets and and chained it down. That gave us the reach we needed and we got them set.
If all goes well, I hope to have it fully framed in 3 days. Once that's done, it's going to depend on weather, we stay pretty windy here and it's going to be tough to do siding and roofing if I don't get some calmer days.
/ My shop build #43
That forklift sure is useful.
Is that you in the pink camo?
/ My shop build
LOL, no that's my fair skinned, redheaded wife. She's always covered from head to toe, the sun is rough on her.
/ My shop build #45
Following. You are truly amazing. This project gives me inspiration. Thank you!
/ My shop build #46
Honestly, I didn't mind writing the check for the building, it's above ground and I can see it. The concrete, on the other hand, that check hurt.
Oh i didn't mind either. It was just a really small pile for $20K. As to the concrete I didn't mind that at all and I appreciate it everytime I sweep or roll my welding table around on my smooth, crack free concrete. :)
/ My shop build
Thanks but really, there isn't anything that complicated about this, the building is just a giant piece of Ikea furniture. It doesn't give you the assembly order but, shows all the details so if you can follow a plan and turn a wrench, you can put the building together. The skill comes when the siding and roof go on, not everyone can get those straight, especially the roof lines. Hopefully, mine turns out correctly.
/ My shop build #48
I agree. I would only add that the precision used when "squaring" the framework will come to light when the roof and siding are added. As my Grandpa would say "measure twice, cut once". :)
Thanks for posting your progress!!! :)
/ My shop build
So, I lost the last couple of days because of a bearing failure on my steer axle spindle. When I bought it, there wasn't a lot of room to drive it around much and test it and once I got it here, I felt the tire chunking but, there were some nasty chunks missing from the tire and I thought that was what was causing it but, turned out it was this.
The shop that's repairing it was nice enough to drop off a loaner and pick mine up today so I was able to get back to work and make some real progress. I'd normally have fixed the forklift myself but, time is in short supply and I kind of need the shop done to have the space to work on it, so...
Here's today's progress.
Tomorrow I'm hoping to get the roof purlins up, the rest of the side wall bracing done, square everything up and torque it down and get the walk door installed. Then comes the hard part with our normal 10MPH - 15MPH winds. We get a couple of calm hours early and late so I guess I'll just have to make the most of those.
/ My shop build #50
Are you going to paint or otherwise mark the bolts as you go through the torquing process? It seems like there are plenty of ways to get distracted and miss one.
/ My shop build
That's not a bad idea. My plan was to put one person on a pallet and another driving the forklift and just go from column to column, working from bottom to top, until we got them all. A Sharpie mark on the bolt head wouldn't take much extra time and would give us positive confirmation that they'd all been touched.
/ My shop build
Got slowed down a little bit last week by "Safety Dog." She doesn't like this loaner forklift and definitely doesn't like it when a person goes up on it to do elevated work. We were working around it but, when she climbed into the cab with my wife, we had to come up with another solution so I ended up going and renting a man lift. Finished up the roof girts and cross bracing Friday, got the walk door installed before getting rained out Saturday and finished the base and rake trim Sunday. Today I'm putting on the J-Trim around the doors, fixing the plumb on one end wall and then starting the sheeting.
IMG_20170202_154213803.jpg IMG_20170202_165344954.jpg IMG_20170205_140742697.jpg IMG_20170205_180706939.jpg
/ My shop build #54
Nice progress. I for one am certainly glad 'safety dog' "convinced" you to rent the manlift.
You're gonna have an AWESOME workspace!
Terry
/ My shop build #55
Lookin good!!!!
Take your time with this part. Accurately "square" the frame and the rest will go on easily.
Thanks for posting the progress pics!!!
/ My shop build
Terry
The only issue is that the lift is an additional $750 I wasn't planning on spending. Plus, now she's starting to complain about the lack of hardhats and steel toes...
/ My shop build #57
If you drop anything of that size and weight on your head or your toes, the steel cap can sever your toes and the the hard hat just makes sure you can have an open casket.
/ My shop build
Not much accomplished today, wind was blowing 15+ all day which doesn't mix well with a 48 square foot metal sail. I got the j-channel cut, some of it installed and pre-drilled the siding panels. Wind is supposed to lay down overnight for a couple of days so, we'll be ready to go first thing in the morning if that holds true.
/ My shop build #59
Yep, wind is definitely not your friend!!!! Now imagine trying to wrap insulation. :)
/ My shop build #60
In my younger days I worked for a contractor who took any and all jobs, he was a sheet metal contractor, but we did anything industrial, from rigging to dust collector piping
All the jobs we did, really the only one I did not enjoy was insulating and siding a steel building
Repetitive and a PITA
Bush Hog 285' 3Pt Mower (A66285)
Bush Hog 285' 3Pt...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2004 Case JX75 (A64126)
2004 Case JX75...
