Intercom to shop
/ Intercom to shop #1
Baldbigears
Hueytown, ALabama
JD 430, Kub 2750
Anybody have suggestions for a kitchen to shop intercom. Distance as wire would run would be close to 200 feet. Wireless won't work because shop is metal building. 120 volt receptacle plug in units won't work because shop has its own electric meter and ground system.
/ Intercom to shop #2
I have intercom that works thru my phone line. but i ran copper wire for phone years ago. I use a commercial phone/intercom system. Its worked flawlessly for 20 years.
but if you dont have buried phone line….it gets alot harder.
my system uses 7 phones with units in basement, master bed, kitchen, office, shop, barn and carriage barn. About 250’ between house and barn and same between house and shop.
/ Intercom to shop #3
The security guys at work recommended this to me when I had a similar situation. Almost 300 ft and 5 years without any issues.
/ Intercom to shop #5
Cell phone
While @Baldbigears shop is apparently metal, that might be a tad difficult. But picking up on the theme, how about a small cellphone repeater into the shop? It might have more uses than just an intercom....
All the best,
Peter
/ Intercom to shop #6
All the best,
Peter
My barn is metal, but I have no issues with using my cell phone in there.
/ Intercom to shop #8
Dear Lord, why would you want that?
Give up that peace and quiet?
:ROFLMAO:
How hard would it be to run a conduit underground from point A to point B?
And my cell phone works in my metal shop building, no problem.
/ Intercom to shop #9
All the best,
Peter
Why not use a wireless bridge? You can then use wifi calling on your phone
/ Intercom to shop #10
Install a second POTS phone line in the shop
Dig a trench and bury an internet connection between the house and shop
Wireless point to point internet/LAN between the house and barn
Bring your cellphone into the shop
BTW I have a wireless driveway alarm >1,000 feet away at one of my farm entrances and I get a signal in my all steel barn
/ Intercom to shop #11
If you have wifi get a couple of Amazon Echo Dots. We have several in the house and they make great intercoms as well as supplying some free entertainment
/ Intercom to shop #12
I have a pair of Kenwood handi-talkies. KPG-87D. Rechargeable LI batteries and, supposedly, five mile range. Operate under the FCC - MURS program. One kept at home - the other with me - anywhere on my property. No muss - no fuss. 100% operation - 100% of the time.
/ Intercom to shop #13
This is what i use to receive cell and wifi inside my metal shop. I could never use cell phone inside shop. I also need computer to run my cnc plasma table, with this i am able to do both. I switched my phone to wifi calling. I now have full phone use deep inside steel building.
/ Intercom to shop #14
I was going to suggest something like that myself. When we bought this place I got a pair of walkie talkies for ~$20 at HD for this purpose. They do the job.
/ Intercom to shop #15
My cell phone works fine in my barn.
It's metal and insulated. Honestly, I don't care to be bothered while I'm there. I'd prefer NOT to have a direct line to the house. If it's that urgent, walk the 400' to the barn. Funny, it's never that urgent
/ Intercom to shop #16
It might be worth it to pull CAT 5 or CAT 6 wire to the shop for internet connectivity.
I'd probably pull two runs. However, at least for the older Ethernet connections, the middle four wires were not used by Ethernet and could be used for phone or intercom.
There could be advantages of also pulling coax.
/ Intercom to shop #17
Since the house and the shop are on different power supplies, and given the distance, and the location (weather), if it were me, I would not pull a conductor. Wireless point to point WiFi, or cellular amplifier would be my choices.
Ethernet (cat5) is good for a maximum distance of 100m/330' with good cable. Cat6 is only good for 55m/180', and Cat 6A is good for up to 100m/330'. To me the issue is going to be lightning storms and the induced voltage on long ethernet runs outside, and the different power supply and grounds in the two buildings is likely to make it worse.
All the best,
Peter
/ Intercom to shop #18
Good points. Another option would be to run fiber. No grounding issues, and you can make a lot longer runs, though it is a bit fragile. Unless you have other wiring to pull, the point-to-point IP link would probably be the easiest option.
/ Intercom to shop #20
My son keeps telling me to carry my cell phone when I'm out on the property. I know from personal experience - it takes the Paramedics 45 minutes to reach my place.
42+ years out here and by being observant and careful - no really serious conditions have ever happened.
I - now - knock on wood. But what else can an old widowed fellow do.
AND - don't ask me to give up the property and move into town. My son has already tried that - once.
2017 International HX620 Quint Dump (A62613)
2017 International...
Kuhn Axis 50.2 Fertilizer Spreader (A64047)
Kuhn Axis 50.2...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
Invoices (A63116)
Invoices (A63116)
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
