Electrical question
/ Electrical question #62
Anyone know why a 12 AWG is allowed for a 20A 120v single phase circuit but 10 AWG is required for a 30A 2 phase 240v circuit? The 30A 240v is actually carrying less amps per wire than the 20A 120v.
60 replies and maybe I missed it but NOBODY questions the electrical knowledge of someone talking about a 2 phase circuit?
Sorry, but that indicates immediately the OP needs a lot of training to be safe.
/ Electrical question #63
Post #6 did address that
/ Electrical question #64
Seeing as I had two years of training and ran the nuclear power plant on a submarine for 6 years and then repaired industrial 3 phase equipment for another 5, I think I'm safe.
I should have used the term split phase instead of 2 phase
/ Electrical question #68
When the magnetic core of a 600V 100Kw is saturated during a dead short . The short current current is lower than a shorter 208V 100Kw transformer .
Yes , but the Power output to the resistive "short" is greater due less loss in the lines supporting the current.
Really beside the point of the 1st example you made comparing the arc you can get from a 12V batt to that available from a power line.​
Its easy to drive high current with high voltage. Transformers serving neighborhoods can source high current and wires leading to the short dont need to be large to conduct thousands of Amps briefly thru your main breaker to service a short. Huge Watts.
With 12V you must have a very specialized battery and huge conductors to service those currents ... and the comparable Watts available at short are even more unattainable.​
2027 . 500k BTU Wellhead Heater (A67714)
2027 . 500k BTU...
2025 JMR 38in Hydraulic Rock Grapple Bucket Mini Skid Steer Attachment (A66734)
2025 JMR 38in...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2013 Mazda 3 Sedan (A66738)
2013 Mazda 3 Sedan...
Ez-Go Freedom Electric Golf Cart (A64912)
Ez-Go Freedom...
2002 FORD F-250 PICKUP TRUCK (A66091)
2002 FORD F-250...
