Serge Colle
- Joined
- Feb 23, 2026
- Messages
- 13
- Tractor
- Backhoe JD310A
Today we started the implementation:
yes we know the backhoe is rusted
. We do have a plan project, for that too.
- Installed all the lights. Used adhesive lock nuts on all bolts to ensure nothing comes loose.
- Installed the grommets for the upper spotlights.
- Determined the best location for the rocker switch panel (voltmeter and USB port): top center of the rollover bar, within reach of the driver’s seat.
- Identified and installed the best location for the cabin fuse box: on the left side of the cab.
- Ran wiring for the four upper spotlights (positive and ground).
- All wires are routed inside a wire harness (except at the corners for now.
- All connections were crimped and sealed with heat shrink tubing to ensure secure connections and eliminate any risk of short circuits.
