ANOTHER ELECTRICAL QUESTION
/ ANOTHER ELECTRICAL QUESTION
Its not the same thing. You cannot legally supply each leg with a different separately derived device. Parallel generators double output but its for 120 only.. theres nothing to wake up and learn about. Ive been an electrical contractor for nearly 40 years. If you want to do this, than do it. Just don’t expect anyone to condone it or tell you its ok to do.. personally i am done with this, i am unsubscribing to it.
It sounds like you are saying I am expecting to get 240 volts from the two 120 volt legs of the parallel switch/kit. I AM NOT. I am only expecting to get two 120 volt legs from the parallel receptacle for a total of 50 amps service. That's what Champion says the #100319 output is.
/ ANOTHER ELECTRICAL QUESTION #62
You better look again! The parallel kit only supplies 1 leg of 120! It might be a 50 240 plug but only one leg is powered! I've been around generators and wiring quite a lot since I also deal with coastal storm and multiple day outages. The picture from Champion shows only 120 on a 240 plug!
Might not catch spell check but seem to know what I'm talking about since also sold Honda generators that offered parallel kits long before Champion ever was in business and it just double amperage not 2 120 legs at 50 amps! 100319-panel-1112x0-c-default.jpeg
/ ANOTHER ELECTRICAL QUESTION #63
Also, if it were 2 legs of 120, why is there only 1 circut breaker for 50 amps? You can't have 2 legs protected by a single 50 amp breaker, it would be 2 25 amp breakers. One for each leg. You need to heed your own advise and study before saying others need to. You should ask the question and take the advice, good and bad! Many post have spelling errors that should be looked past for content!
/ ANOTHER ELECTRICAL QUESTION #68
Might not catch spell check but seem to know what I'm talking about since also sold Honda generators that offered parallel kits long before Champion ever was in business and it just double amperage not 2 120 legs at 50 amps!View attachment 666333
I really do believe you know what you're talking about but please explain the 50 amp receptacle in the parallel kit picture you posted. Looking at the receptacle as pictured: The semi-rounded slot on the left is ground? The slot on the right is neutral? Both the top and bottom slots are 120 volts? I realize they are both on the same circuit but do not both of them provide 120 volts? Please explain. I'm listening.
Here's a bunch of interlock kits for under $100
https://www.homedepot.com/p/Square-...r-Generator-Interlock-Kit-HOMRBGK2C/203030954
But you need a 240v generator.
In all reality, if you're dead set on using two generators to supply 120v only, you'd be better off and a lot safer just running extension cords to each item VS cobbling up your sub panel every time there's a power outage.
I would love to use an interlock kit rather than a transfer switch. Much cheaper and easier and just as safe. However, my sub-panel (Siemens) does not have a main, only branch circuit breakers. The main for the sub-panel is in the outside panel.
OK, I have another confession to make. I do own a 5500 watt 240 volt generator. It is loud as all get out and the voltage fluctuates pretty wildly when a load is applied (like a compressor starting on a refrigerator, freezer or window ac). I'm very concerned about my electronics using this generator. I CAN use it if I have to. I just don't really want to if I can help it.
The 240v generator has a bonded neutral. (I just checked it) I know the smaller ones have a floating neutral. (Checked them too) If I do buy the 100 amp transfer switch I still do not know how to hook up the neutrals or grounds from either generator. That has been my only question from the beginning of this post. THANKS for your help and advice. I really do appreciate it.
/ ANOTHER ELECTRICAL QUESTION #73
^^Use that one to power the panel. It'll run the furnace blower, water heater and all the motor appliances (unless you have the fancy 'smarty pants ones). Get the transfer witch with a twist lock 240V socket (or one add later) and a special generator cordset with two male twist lock plugs. That will connect the ground, neutral and both hots. You'll have to control your loads. You won't be able to run the water heater, range and dryer all at once for example, but you may be able to run each separately if you don't have much else running.
Use the smaller inverter generator on extension cords to power your computer, etc.
/ ANOTHER ELECTRICAL QUESTION #74
You can use a sub panel interlock.
A generator plug outside
And costco has a dual fuel Firman generator with a true 50 amp 240 volt and is in the "mid range' on noise level. For $699.00 with a lifetime warranty. Ive had mine over a year and ran it nonstop for 6 months to power my 50amp 5th wheel with 2 atc units after the floods in the Midwest.JPEG_20200816_110536_2003230777.jpgScreenshot_20200816-105126.jpgScreenshot_20200816-110847.jpg
/ ANOTHER ELECTRICAL QUESTION #75
And I forgot to add that no matter which way you go you HAVE to have a Fail-Safe transfer switch, whether it is a manual interlock, a manual transfer switch or an automatic transfer switch Lineman's lives depend on it.
I install a lot of household generators and there are a lot of options you could even do an on off on throw switch mounted outside as well.
On- utility power
Off- no power to panel
On- generaror power
Another point that I don't believe I saw mentioned was running one generator should be more fuel efficient than running two generators.
/ ANOTHER ELECTRICAL QUESTION #76
For all the FEAR around people backfeeding lines, it astounds me that, that cheesy latch assembly is all that it takes to meet compliance.
/ ANOTHER ELECTRICAL QUESTION #77
Yep, it is crazy. And that is one for a subpanel, the ones for main panels are a lot more heavy-duty but a manual or automatic transfer switch is definitely the choice for myself.
/ ANOTHER ELECTRICAL QUESTION #78
Makes you wonder, how many people would replace the whole thing if the 2 cent rivet or breaker shell broke?
I don't have a furnace blower, electric water heater, or electric range. (All gas) The only 240v things I have is a clothes dryer and central ac. An old fashioned clothes line will replace the dryer and the central ac will sit idle. A small window unit will keep us cool at night. That's why I'm trying to figure out the easiest and cheapest way to get us through a power outage. Practically all the lights in the house are led, my refrigerator and freezer are both newer and energy efficient and satellite receiver and televisions consume very little current. The biggest energy hogs we have are hair dryers and microwaves. Both would be idle during an outage.
/ ANOTHER ELECTRICAL QUESTION #80
Your cheapest way is with extension cords to your existing generators. Fool proof (well, fool resistant at least :rolleyes:), with no chance of backfeeding another circuit by accident.
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
2018 Ford Escape AWD SUV (A59231)
2018 Ford Escape...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2013 Ford F-450 Service Truck (A59230)
2013 Ford F-450...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
