ANOTHER ELECTRICAL QUESTION
   / ANOTHER ELECTRICAL QUESTION
Its not the same thing. You cannot legally supply each leg with a different separately derived device. Parallel generators double output but its for 120 only.. theres nothing to wake up and learn about. Ive been an electrical contractor for nearly 40 years. If you want to do this, than do it. Just don’t expect anyone to condone it or tell you its ok to do.. personally i am done with this, i am unsubscribing to it.
It sounds like you are saying I am expecting to get 240 volts from the two 120 volt legs of the parallel switch/kit. I AM NOT. I am only expecting to get two 120 volt legs from the parallel receptacle for a total of 50 amps service. That's what Champion says the #100319 output is.
   / ANOTHER ELECTRICAL QUESTION #62
You better look again! The parallel kit only supplies 1 leg of 120! It might be a 50 240 plug but only one leg is powered! I've been around generators and wiring quite a lot since I also deal with coastal storm and multiple day outages. The picture from Champion shows only 120 on a 240 plug!
Might not catch spell check but seem to know what I'm talking about since also sold Honda generators that offered parallel kits long before Champion ever was in business and it just double amperage not 2 120 legs at 50 amps! 100319-panel-1112x0-c-default.jpeg
   / ANOTHER ELECTRICAL QUESTION #63
Also, if it were 2 legs of 120, why is there only 1 circut breaker for 50 amps? You can't have 2 legs protected by a single 50 amp breaker, it would be 2 25 amp breakers. One for each leg. You need to heed your own advise and study before saying others need to. You should ask the question and take the advice, good and bad! Many post have spelling errors that should be looked past for content!
   / ANOTHER ELECTRICAL QUESTION #68
LOT: Steel File Cabinets, Steel Cabinets, Primo Electric Water Cooler (A59076)
LOT: Steel File...
2012 Western Star Trucks 4900 SA Truck, VIN # 5KJJALDV0CPBE2239 (A57453)
2012 Western Star...
UNUSED FUTURE D39 39" MINI HYD TRENCHER (A58376)
UNUSED FUTURE D39...
2006 JLG 450AJ SERIES II TELESCOPIC BOOM LIFT (A52709)
2006 JLG 450AJ...
Rooster Weathervane (A55853)
Rooster...
Giyi Mini 40" Land Leveler (A57149)
Giyi Mini 40" Land...
