3 Phase?
/ 3 Phase? #31
I see closed delta with one center tapped phase. If you can utilize it you have a gold mine. You can get 3 phase 240, single phase 240, 208, and 120. Closed delta is common in VT, almost always if this voltage center tapped. A very versatile system. I am concerned, in VT you would be on a demand rate. Peak load factors against usage. Don't use much power, but peak out the load 15 minutes a month I.E. Stick a welder, you pay through the nose.
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A61165)
2004 MCI D4500...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
2019 GALLEGOS TRAILER PNEUMATIC TRAILER (A60736)
2019 GALLEGOS...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
