Haven't had a BatteryMINDer or PulseTech go bad yet, just the one little NOCO.
Started using the B-minders in the 90s, and many of them have been in use just about 24/7 since.
Maybe eight years ago I got the first modern PulseTech, then two of the newest ones introduced about a year ago. The first one is hooked to my Ram 3500 at least 95 % of the time - it's not driven often.
My little NOCO killed a battery the first time I used the darn thing. Took out one of a pair of matched H8 batteries. My CTEK is probably 25 years old, but I rarely use it.
Another way to keep batteries happy are the PulseTech desulfators. Started using them recently, have used Canadus for decades. Big difference in price.
I should disclose that our two PulseTech’s are the Xtreme series with the pulser and we are using them as maintainers not so much as chargers. I am also feeding a H8 with it. If it wouldn’t be for the weak power input stage design, I’d give PulseTech the advantage over CTek. I also have the big CTek (7002?). However the Noco 10 is better.
Those little Noco Genius chargers are just trouble. Not sure if they fixed that problem now, but I did have a small Noco Genius 2 on the bench. Killed the battery and itself. It was 7 months old. I fixed it faster than him sending it back for a warranty exchange. Had another one that was about 1.5 years old. Same thing. I put a more beefy part inside and it is still working.
Motormaster and Schumacher battery chargers are utter garbage. Also kill the battery and itself. Not worth a penny.
Optimate is pretty good for charging, but not so good as to maintaining.
BatteryTender: well whilst they look the same between old and new, they are not the same inside. The older ones have a transformer, the newer one is a switch mode power supply and a hunk of metal bolted inside to give it the same weight the old ones had!
It has an STM8 chip inside (don’t bother trying to read it, it’s locked!) Also a lot of broken ones I fixed or not fixed.
It is okish… right between the Noco 2 and Motormaster and Schumacher chargers.
About desulfating:
The bigger Noco, Pulsetech Xtreme, BatteryMinder are excellent if given enough time. Problem is you gotta measure that with a calendar.
I pair Ctek with a homebrew small desulfator (kick back) and it works the same as the others. You need a calendar. Some batteries it isn’t a problem because they are parked a lot.
Why the whole jazz? Because I get at least double or triple the battery life than without it. Otherwise I go broke buying batteries every 2-3 years for ever machine or toy. Piles up fast!
