How do you plow snow?
/ How do you plow snow? #401
I love snow shoes. Got mine stashed in the closet as if I will ever need them here. But used them a lot when I lived out west. That is my old boy Guinness Stout 20+ years ago on a snow shoe hike in Montana.
Hiking in Crater Lake National Park.
Edit: @Gordon Gould had pictures of snow shoes in his post. That sparked my memory.
/ How do you plow snow? #402
I was hoping to see the photos where Mr. Gordon dragged back that downed tree...guess that is for tomorrow's post!
/ How do you plow snow? #404
We're in north central PA, and a welcomed warming trend has hit!
Above freezing both day and night for the last 2 days and next 4 days, which will melt off our 8 inches of snow.
The way the 1st snow happened this year, the ground (and gravel on the drive) was not frozen when we got a big snow, and the conditions resulted in more gravel embedded in the snow berms than desired, in spite of keeping the blade above the gravel when plowing.
So yesterday I was able to "reverse plow" the snow banks, angling the back blade in the opposite direction to plow the snow banks and embedded gravel back onto the driveway.
This has resulted in the snow melt leaving the gravel back on the driveway rather than the lawn and side ditches.
I spread out the snow I plowed back in and ran over the bigger chunks with the tractor tires...and at this point, the snow is mostly gone, leaving the gravel behind...
Timing is everything in being successful with this...but it seems to have worked out better than I expected for the small amount of time and effort required.
/ How do you plow snow? #406
I wish I could, but winter hasn't started here yet.
Although, about 15 miles to the north there's an avalanche warning. Meanwhile, an hour east of here there's a red flag warning.
/ How do you plow snow? #408
Going to be 68F in MO today and supposed to be warm through end of the month, so I may done plowing snow for the season. Might wash the car this afternoon....
/ How do you plow snow? #409
64 here today. The last little pile of snow I had stacked up melted a few days ago. It’s suppose to get cold again starting Friday but no snow predicted.
/ How do you plow snow? #414
Here's my two main snow machines. Just fueling up after I cleaned yard yesterday. I haven't even put the blower on the tractor the last two winters ever since I put one on the RTV. Previously had a Boss vee plow on the RTV.
Now I just use the tractor to cut and scrape with the blade and loader once in a while. I keep the skid shoes down quite a bit on the blower so after a while I get some buildup. So then I just go cut with the tractor.
/ How do you plow snow? #415
sick kubota I don't blame you open cab, rear blower vs close cab and front blower its a no brainer ... what power that front snow blower on the RTV? it doesn't look like it has a independent motor on it.
/ How do you plow snow? #416
PTO driveshaft. Part of the K-Connect system.
The good: works great, throws snow farther than my tractor blower.
The bad: loss of ground clearance, so now I don't use my RTV to go atv riding any more. And it's pretty complex and lots of maintenance points.
2004 Talbert Lowboy Detach Trailer (A64047)
2004 Talbert...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
Arrow Quip 5500LV Cattle Chute (A64047)
Arrow Quip 5500LV...
Volvo EC220EL (A60462)
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2021 CAM p4EC16W102 16ft. 7000lb Utility Trailer (A64047)
2021 CAM...
