How do you plow snow?
/ How do you plow snow? #301
Inertia is a good thing!
Once he started the side to side jiggle (while bellied out) it can quickly end. Forward progress that is.
I didn't notice any kind of plow on that tractor!
/ How do you plow snow? #303
My wife and I were watching the weather forecast, and I told her "It looks like you can expect to get a good 3 inches tonight." I thought it was funnier than she did. :oops:
/ How do you plow snow? #305
We're at camp tonight and found 2+ feet of new snow here. Was rubbing the bottom of the 6x6 as I pushed it around. Will post pics when we get home.
/ How do you plow snow? #306
scootr, Doesn't look like they got much "plowed" ...
  • Good Post
Reactions: JJT
/ How do you plow snow? #307
Been wondering how a UTV plow was going to deal with your situation. I know mine was not great once it got over 12", but I do not have a lot of patience. Broke two shear pins on mine.
Love following your write ups. Makes me wish I was 30 years younger, but this old man needs things that take less effort.
/ How do you plow snow? #308
Trust me, I can't do 1/2 the things I could, even 5 years ago. None of the plows we've owned have had sear pins. Looking for some plow to add to the 4x4 atv we are supposed to pick up Monday.
/ How do you plow snow? #310
We decided the base here is 3+ foot at camp and pulling slash into the woods has near impossible. Our 6x6 can still tootle around in that snow with its low, low psi but getting hungup on unseen objects becomes the issue. When we plow, we are near idle and never get out of low range for most of the winter. So its using its traction to push the plow. While going reasonably slow and on a atv, its easy to see your blade and miss things you didn't want to bite, like a building. But of course in soft, deep, snow that hids everything you still find that boulder. I've never plowed with a rubber tire equipped machine.
/ How do you plow snow? #311
As long as you keep the tires on a solid surface as you plow you should be fine. I used chains on the Ranger after I got rid of the pods. If you try riding into 12-14" of snow, you are toast. Once the floor pan is being held up by the snow under it, you are done.
You might want to consider a sled with a tow sled like this to move stuff from your parking area up the trail to you cabin:
/ How do you plow snow? #313
Arly I won't begin to give you any snow advice, but with all your grooming experience....
rather than plowing in from your parking area to the cabin wouldn't a packing/grooming treatment be the best approach for your amazing snows?👍
/ How do you plow snow? #314
Oh gee, I'm plowing some at the parking area and at camp, but no where else. In my camp thread, you will see photos of the roller we do the road in with. It's completely impractical to plow the mile in.
/ How do you plow snow? #317
Already in January and finally last night, mounted up the Inverted blower. This winter "so far" is more like a wet fall than an actual winter.
Second pic
Same time of year, and same place where the tractor is parked now but in 2022
/ How do you plow snow? #320
We've had the warmest December ever, and were braking records pretty much all of last year.
If we do get snow at some point, by now my plowing skills will be marginally better than when I first got the tractor.
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
Unused 2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
2007 Mack CHN613 T/A Day Cab Truck Tractor (A66736)
2007 Mack CHN613...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A64557)
2018 Freightliner...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
