How do you plow snow?
/ How do you plow snow? #41
@Hay Dude I understood what Arly meant. Growing up in the North (due west of the Twin Cities), we always had real snow. Maybe 1 of 3 Halloweens, we trick or treated in parkas and snow boots with a foot or more on the ground. 20 years in Texas, we've maybe had 3 years that had real snow and they were typically just one storm each.
To me, 'real snow' means you actually NEED to get out and remove it. Anything under about 2" it's almost easier to just let the sun, wind, and friction remove it. Other factors may come into play, dry vs wet snow, surface type, or slope, to name a few. It is highly unlikely I will ever need to remove snow again. If I do, it would simply be a loader bucket job.
Our first winter in Wisconsin, we had 55" of snow just in December. That was real snow. We seemed to get 4-8" every 3 or 4 days. The rest of that winter, we had little 'real snow'. A dusting of dry snow is 'fake'.
/ How do you plow snow? #42
Real snow pictured here.
/ How do you plow snow? #43
@Torvy,
I could not imagine living in the misery of being cold & snowbound like that for so much of the year. Also the energy and expenses exerted to clear roads, walkways, campuses for that much of a year. It would be like prison to me. Talk about carbon emissions, wow, all those trucks running day & night clearing snow. All the road salt spread on roads ends up in the water and the ecosystems.
We usually get 4 or 5 2”-10” snowfalls per year here and they must be cleared or they will turn into packed ice, which is much more dangerous. 2” of snow left unplowed in cold weather is a nightmare for my customers as we don’t run around with chains or studded snow tires for months at a time.
Once every 5 years or so, we’ll get 2 feet of snow and it gives you a window into the drudgery of removing it constantly like someone in Michigan must endure. No thanks. I have better things to do than deal with shoveling snow, frozen rain gutters, tire chains and $1,000 heat bills for 7 months a year.
I have been in the commercial and residential snowplowing business for 30 years, so I have seen years where we got 30” of snow in one shot, and 3” of snow in an entire winter. The small amount of snow we usually get here is plenty enough for me and puts a little extra $$ in the bank account.
/ How do you plow snow? #44
This year we were supposed to have a colder, wetter winter. So far i have not installed snow gear or chains. Generally i start with plow until i get nice consistent cold weather to keep rocks out of blower. Then use blower until spring. As i get older i get lazier. I installed heated mats on front steps so i dont have to shovel. The wife pushes a small gas snowblower to maintain some foot paths.
/ How do you plow snow? #45
ATV snowplow attached to the frame and box blade to pull the snow away from buildings. Originally I used the FEL and then tried a rear mounted snow blower. The plow has turned out to the be the fastest, easiest solution, since we usually don't get over 100 inches a year.
/ How do you plow snow? #46
Moose blade?
/ How do you plow snow? #47
I can’t imagine the workload of being 60++ and living in the countryside on a budget in a heavy snow climate. Getting out there and plowing, salting, shoveling, ice chipping….100++ inches per year.
I’d move to warm, sunny climate 😁 :cool:. I can barely stand the winters here and they are “only” 3-4 months. I have to work outside every day and that’s hard enough on the body, but at least we can still work in the woods. Couldn’t imagine trying to work with 25” of snow on the ground messing everything up. Then adding months of snow shoveling, snow plowing, salting, ice chipping…
If the kids have left the home, there’s no sons around to help. Now you have to pay more money for help. Astronomical heating bills, too. Especially with the way energy prices went up from ‘20-‘24.
YUCK lol
/ How do you plow snow? #51
Oops that was supposed to be 1,400 pounds not 14,000
That's still pretty chunky for that tractor. I bet you don't get much blade chatter with that!
My 8 footer weighs about 850lbs, and it's a heavy duty model.
/ How do you plow snow? #52
Haydude, people adapt. I’m pretty sure people like Arly enjoy it. I’m with you though, that much would get old.
A picture of what I use.View attachment 4420436
Yeah I guess you do adapt.
But I adapt to warm sunshine much better. :cool: 😁
Anyways, here’s me plowing some “unreal” snow last winter. Only about 8” so it’s not “real snow” lol
Here’s my “weapons” Challenger 135HP with 8.5’ Arctic snowplow
Same tractor as above, but looking out back. Snow Ex 1850 spreader with tub vibrator. Salting some not “real” ice & snow…. 😁
/ How do you plow snow? #54
/ How do you plow snow? #57
I took a different approach. I built the road up and have big ditches on each side. The wind blows the snow to the ditches.
No need to plow...
Ask me how many years it took to figure that out...
/ How do you plow snow? #58
Chopped made a nice wing plow as well
/ How do you plow snow? #59
No need to plow...
Nice property my friend.
/ How do you plow snow? #60
Fisher plows are made in Maine and are popular here. I've used the old straight permanently mounted blade, a Minute Mount straight blade, an Extreme V, and an XLS - my favorite. The XLS is a straight 8' blade with two hydraulically driven 1' extensions, so an 8' becomes a 10'. What's more, the ends can fold forward creating sort of a scoop for clearing larger areas like small parking lots without losing much of the captured snow on the way to the bank. V plows are great for breaking through deeper snow or banks left by town/state plows, but I've found they leave a windrow where the two moldboards hinge from. The XLS is a heavier plow and cleans right down to the pavement.
2006 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A67714)
2006 TROXELL 150...
TAG 48" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 48" QUICK...
2012 KENWORTH T800 TRI-AXLE (A67714)
2012 KENWORTH T800...
PALLET OF FLANGES (A68842)
PALLET OF FLANGES...
20' CONNEX BOX (A67714)
20' CONNEX BOX...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
