How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench?
/ How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench? #61
Horizontal Directional Drill is for a 3" is gonna be at least $10/LF for an existing contract, atleast double for a residential customer; vs $1.50/trench/plowed LF.
None of this is rocket surgery, do what the power company wants. Telecom doesnt care; but if anything other than fiber (copper or coax) keep it atleast 12" seperate. Hoe will do fine, probably dig that trench in 45 minutes. Throw spoils to 1 side; keeping other side clear for adding your sand. Sprinkle in a couple inches of sand, glue up all for your conduit, and place as a single piece. Avoid fittings; only bell and spigot pipe; gradual bends by flexing pipe over 45s/sweeps. Call them to inspect, and add the rest of the sand in top, add the roll of tape they asked for, and back fill with the cleanest of the remaining spoil.
Is the utility asking for mule tap or jet line to be installed by you?
Also, have your 811 ticket, virgin land or not, just to cover your butt
/ How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench? #62
I’d be very surprised if you could get 300 ft bored for $20 a ft especially considering the excavating that would have to be done at each end to install the sweeps as well as at least once in the middle probably more. Than there’s the issue of they have 2 utilities to burry so they would have to repeat the process twice. Firing up the Cat 306 that’s available and digging a hole is the clear answer to me. I’d have zero issues with backfilling it a foot and throwing the internet line on top but if anyone feels that strongly about it it’s easy enough to just dig a second ditch beside the first. I’ll say that exactly 0 people have paid me to dig a second trench beside the first one for their internet.
Wish I could did a trench in 45 minutes. Tractor backhoe and the path just doesn't allow for that
A couple other image. Working at the pole was challenging.
/ How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench? #65
You consider running it above ground like the power and internet people do.
/ How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench? #67
Above ground looks trashy also the local utility company requires a 50 ft cut in the air for overhead. That’s at least 75ft on the ground if not more like 100 ft. Clearing 100 ft wide is way harder than digging a hole. I don’t know why people are acting like he’s wanting to build a moon rover here. Digging a 300 ft ditch 3 ft deep with a cat 306 to work with is easy work.
/ How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench? #68
Our electric co-op requires UG, unless specially waved by the board. Telecom isnt going to want to pay joint user attachment fees. For what our OP is doing UG is probably the best choice, and although, in my area, the bedding wouldn't be normal, nothing seems unreasonable. UG power/water/sewer/gas, you really do want to keep real trees atleast 5 ft from the buried utility as well though.
Do call and check if they want jet line or mule tape, as its easier to stuff when gluing, and check if they need to visually see it, and at what stages. Other than that, just dig, and move on
/ How to dig the narrowest 3' deep trench or minimize sand fill for a wide trench? #69
I’m honestly surprised our provider still allows overhead considering they’re responsible for tree damage up to the meter. The jet line takes 10 seconds to pull through with a shopvac and plastic bag. I’ve done it one piece at a time by tying a weight on the line and dropping it through one piece at a time but the shopvac is way easier.
Don't want a pole and wires flying through the air. The only way to go is to do the extra work and get them underground.
1991 TRAILMASTER CRUDE TRAILER (A60736)
1991 TRAILMASTER...
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR6AJ276531 (A61165)
2010 International...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2012 FORD F-250 (INOPERABLE) (A60736)
2012 FORD F-250...
ASSET DESCRIPTIONS & CONDITION (A59908)
ASSET DESCRIPTIONS...
2022 Bobcat T66 R-Series (A60462)
2022 Bobcat T66...
