New 3 stall shop suggestion requests
   / New 3 stall shop suggestion requests
Thanks. Needs gooseneck lights on the exterior, door weatherstrip and deco corners before the exterior is done-done.
Now I am racing Mother Nature so I can heat and work in it this winter.
   / New 3 stall shop suggestion requests #33
Very nice-looking building!!! I really like the two different browns you used for the walls.
   / New 3 stall shop suggestion requests #34
Nice looking building. When you get the inside finished lets see some more pictures.
   / New 3 stall shop suggestion requests #35
Looks GREAT!
Thanks for the update!
Did you go with a "mezzanine"?
I've got a small "mezzanine" in my shed and wish I had an elevator, or at least a dumbwaiter.
   / New 3 stall shop suggestion requests #36
Go with 12' wide 10' high overhead doors, my buddy talked me into it and I'm glad he did. My PB is 40' x 60' x 12'. Propane furnace in shop with overhead fan and well insulated.
No lift here, but my shop floor is 5" thick with rebar 2' centers. My shop 33' x 22' has saw cuts to make 8 sections. Built in 2014 no cracks.
   / New 3 stall shop suggestion requests #37
Have you considered using a coal stoker furnace and burning
North Dakota lignite since it is so inexpensive?
   / New 3 stall shop suggestion requests #38
On the size of overhead doors, I went with 10ft x 10ft. I figured height for my backhoe mounted on my trailer backing through the door. Also the 10ft wide is nice for backing my Tundra pickup into. Truck has tow mirrors, which would probably hit on a normal car garage door width. Jon
  • Good Post
Reactions: JJT
Update:
Blew in 16" of fiberglass last weekend to the tune of R-50ish on top of the white metal ceiling. Really hoping that I have all the attic crap done.
Now onto the wall insulation which be 2 layers of R-13 since 8" thick batts or roll only comes in 24" wide. Oh well. First layer, then wiring, then second layer, poly, OSB then metal. Slow goin' when you're solo.
Outlets for the lights on the ceiling are functional now so I finally have a light SWITCH!!! By the entry door even! Simple things.
I am amazed at how much easier it is to heat now, even holds the heat. Before I closed the attic hatch, I could swear it was colder in the attic than outside.
   / New 3 stall shop suggestion requests #40
That's significant progress, and just in time for winter!!!
I hate installing insulation, but when it's done, everything gets easier.
1991 Snowco Trailer (A59814)
1991 Snowco...
2018 John Deere 1653 (A56436)
2018 John Deere...
2006 GMC C5500 BUCKET /SIGN TRUCK (A59575)
2006 GMC C5500...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
