newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,884
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
If the company stays around for 20 years.Hopefully the last time I need to do that as there warranted 20 years.
Have not bought since 2022 so I could be way off...700 is cheap. They want 1700 for the direct vent units Im looking at…..yeiks. When I bought these rheems they were under 700.
I didn't even know about fiberglass tanks. I'm gonna check into them. I hope I can find one that is propane fired. If I can only find electric then I would need to run wire over 60 feet to power it. That will be expensive. But I really like the idea of a tank that won't corrode.I've had a Marathon Fiberglas / plastic? tank since 2003 so we will see...
FWIW: I've never seen a combustion fired fiberglass water heater. I have seen stainless ones.I didn't even know about fiberglass tanks. I'm gonna check into them. I hope I can find one that is propane fired. If I can only find electric then I would need to run wire over 60 feet to power it. That will be expensive. But I really like the idea of a tank that won't corrode.
Eric
In this day and age, I would go for a heat pump water heater, some of which run on 120V, especially given the cost of power in the NW.
Let us know how the search goes!
All the best,
Peter
Eric
PSE cost per kW is much less than PGE making electric viable?Not sure what you mean by "especially given the cost of power in the NW" ?
Our cost is 8.79 cents / kWh
Yes, I was referring to the regionally cheaper power in the Pacific Northwest, which makes the ROI on an electric water heater or a heat pump water heater more compelling. The latter uses 1/3-1/4 the energy of the former, and even less compared to propane.Not sure what you mean by "especially given the cost of power in the NW" ?
Our cost here in the Pacific Northwest is 8.79 cents / kWh, but please don't tell anyone!
It stayed at 8.13 c/kWh for about 13 years, until just recently it was raised to 8.79
We will see what the future brings?
I guess that I am kind of on the "it is what it is" page, though it does definitely incentivize us to be energy conscious, so we have been pretty proactive with a number of energy projects. It does make for a pretty rapid return on investment for energy investments like solar and heat pumps, despite the high labor and permitting costs here.Ouch, sorry about that!
Is that the total delivered cost per kwh or just the so called electrical cost portion of the bill.Not sure what you mean by "especially given the cost of power in the NW" ?
