Water heater recs please
/ Water heater recs please #102
That, you never know. Thing is due to the cost of metals, Raheem charged me $74.75 for 2 rods in 2023 that I paid $42.27 for the same in 2021. And the prices only keep going up.
And they only last 2-3 years before really start to fall apart. So the electronic is actually cheaper.
/ Water heater recs please #103
I miss the old Hoyt Lifetime water heaters with copper tank... they had a long history in Oakland CA and then relocated to Reno NV and now no more.
When I buy gas it's now Bradford White... so far so good but cost $700 and up for California approved.
/ Water heater recs please #104
700 is cheap. They want 1700 for the direct vent units Im looking at…..yeiks. When I bought these rheems they were under 700.
/ Water heater recs please #105
Have not bought since 2022 so I could be way off...
/ Water heater recs please #106
I use a Marathon fiberglass wound HWH. The tank lasts a lifetime. Doesn't corrode, so there is no anode to worry about. Since the heating element doesn't get coated with metallic corrosion, all of the heat is transferred to the water instead of being insulated by scale. So the heater also lasts a long time.
/ Water heater recs please #107
I've had a Marathon Fiberglas / plastic? tank since 2003 so we will see...
/ Water heater recs please #108
I installed a 40 gallon Marathon in 2009 to replace an oil fired water heater.
/ Water heater recs please #109
I've been using a 40+ gallon Boilermate for almost 30 years.
I didn't even know about fiberglass tanks. I'm gonna check into them. I hope I can find one that is propane fired. If I can only find electric then I would need to run wire over 60 feet to power it. That will be expensive. But I really like the idea of a tank that won't corrode.
Eric
/ Water heater recs please #111
Eric
FWIW: I've never seen a combustion fired fiberglass water heater. I have seen stainless ones.
In this day and age, I would go for a heat pump water heater, some of which run on 120V, especially given the cost of power in the NW.
Let us know how the search goes!
All the best,
Peter
/ Water heater recs please #112
Steel, Stainless or Copper gas fired is my experience…
Hoyt Copper tank made in Oakland CA is the longest lasting I have come across… forever warranty also… that is until the company was bought out and moved to Nevada and the name no longer exists.
I had one dated 1950 going strong and was still in the house 50 years later when sold.
/ Water heater recs please #113
We went from an electric tank to a gas tankless. I will never go back! There are 4 of us here now, but I love never running out of hot water. I also talked to a guy from HVAC services in Fair Oaks https://alphamechanicals.com/service-area/fair-oaks-hvac-service/ about this, and he said that if it's in the budget, they always recommend gas tankless to their clients.
Among other benefits - utility cost savings, space saving, and if you pay a bit more for one with the internal buffer tank and circulator, the wait for hot water is mitigated.
/ Water heater recs please #114
All the best,
Peter
Not sure what you mean by "especially given the cost of power in the NW" ?
Our cost here in the Pacific Northwest is 8.79 cents / kWh, but please don't tell anyone!
It stayed at 8.13 c/kWh for about 13 years, until just recently it was raised to 8.79
We will see what the future brings?
/ Water heater recs please #115
Eric
We have a year 2003 version of this:
  • 104-1_Marathon_SellingGuide_Rev11.pdf
/ Water heater recs please #116
Our cost is 8.79 cents / kWh
PSE cost per kW is much less than PGE making electric viable?
/ Water heater recs please #117
Yes, I was referring to the regionally cheaper power in the Pacific Northwest, which makes the ROI on an electric water heater or a heat pump water heater more compelling. The latter uses 1/3-1/4 the energy of the former, and even less compared to propane.
Just for comparison, here the "off peak"(0:00-15:00) power is $0.35/kWh, "peak" (16:00-21:00) is $0.66/kWh.
Propane is $2.75-$5./gal
All the best,
Peter
/ Water heater recs please #118
Ouch, sorry about that!
/ Water heater recs please #119
I guess that I am kind of on the "it is what it is" page, though it does definitely incentivize us to be energy conscious, so we have been pretty proactive with a number of energy projects. It does make for a pretty rapid return on investment for energy investments like solar and heat pumps, despite the high labor and permitting costs here.
I used to live where intense weather was more common, but you still had to go out and care for the animals or the farm, so perhaps I lean a bit more toward the "it is what it is", and getting on with life.🤷‍♂️
All the best,
Peter
/ Water heater recs please #120
Is that the total delivered cost per kwh or just the so called electrical cost portion of the bill.
My $0.18 to $0.20 per kwh is the actual delivered cost while the so called electrical amount is listed as $0.06 or $0.08 per kwh.
2010 Kenworth T3 Class 7 Flatbed, 4x2, w Tuck-Under Liftgate (A63689)
2010 Kenworth T3...
IRanch High-End Tricycle (A64119)
IRanch High-End...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
2005 Freightliner M2 106 Ambulance (A61573)
2005 Freightliner...
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
