Water heater recs please
   / Water heater recs please #102
That, you never know. Thing is due to the cost of metals, Raheem charged me $74.75 for 2 rods in 2023 that I paid $42.27 for the same in 2021. And the prices only keep going up.
And they only last 2-3 years before really start to fall apart. So the electronic is actually cheaper.
   / Water heater recs please #103
I miss the old Hoyt Lifetime water heaters with copper tank... they had a long history in Oakland CA and then relocated to Reno NV and now no more.
When I buy gas it's now Bradford White... so far so good but cost $700 and up for California approved.
   / Water heater recs please #104
700 is cheap. They want 1700 for the direct vent units Im looking at…..yeiks. When I bought these rheems they were under 700.
   / Water heater recs please #105
Have not bought since 2022 so I could be way off...
   / Water heater recs please #106
I use a Marathon fiberglass wound HWH. The tank lasts a lifetime. Doesn't corrode, so there is no anode to worry about. Since the heating element doesn't get coated with metallic corrosion, all of the heat is transferred to the water instead of being insulated by scale. So the heater also lasts a long time.
   / Water heater recs please #107
I've had a Marathon Fiberglas / plastic? tank since 2003 so we will see...
   / Water heater recs please #108
I installed a 40 gallon Marathon in 2009 to replace an oil fired water heater.
   / Water heater recs please #109
I've been using a 40+ gallon Boilermate for almost 30 years.
I didn't even know about fiberglass tanks. I'm gonna check into them. I hope I can find one that is propane fired. If I can only find electric then I would need to run wire over 60 feet to power it. That will be expensive. But I really like the idea of a tank that won't corrode.
Eric
2001 HEIL PNEUMATIC CEMENT TRAILER (A52576)
2001 HEIL...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
2018 CHEVROLET 2500 SILVERADO (A52472)
2018 CHEVROLET...
2019 FORD TRANSIT 350HD VAN (A52576)
2019 FORD TRANSIT...
1274 (A50490)
1274 (A50490)
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
