Water heater recs please
   / Water heater recs please #131
   / Water heater recs please #132
Just go to a local HVAC supply warehouse where plumbers and contractors buy. Most will still sell retail and they have about anything in stock. Don’t go to Home Depot.
   / Water heater recs please #133
I didn't even know about fiberglass tanks. I'm gonna check into them. I hope I can find one that is propane fired. If I can only find electric then I would need to run wire over 60 feet to power it. That will be expensive. But I really like the idea of a tank that won't corrode.
Eric
What did you decide in the end?
All the best,
Peter
All the best,
Peter
I am looking at tankless water heaters now. I can pretty easily run a larger pipe for the propane if need be. I will update this search soon. This month or next month I will be making the purchase. I just had to spend $2500.00 that I didn't plan for so it will probably be next month that I buy the heater. Anyway, thanks for asking, I should have posted something already.
Eric
   / Water heater recs please #135
For 20 or so years gas water heaters here have a C/O detector and everyone eventually goes bad.
Some are stand alone and others integral with the thermopile.
Are sealed combustion gas water heaters with CO shutdown nationwide?
   / Water heater recs please #136
Add me down for another tankless water heater. We've had ours for 13 years. Never a failure, never a shortage of hot water. It uses a fraction of the amount of propane our old tank type heater used. Hot water on demand and endless supply.
The only change I'd make is to add an additonal small one for under the kitchen sink, which is the farthest from the central unit. Spouse wants instant hot water when she turns that faucet on! She's not tollerent of waiting for the hot water to make the journey across the house.
2011 GMC DENALI HD PICKUP TRUCK (A59575)
2011 GMC DENALI HD...
MULCHER (A58216)
MULCHER (A58216)
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
HOMEMADE JOHN DEERE 98"X27' DBL AXLE HAY TRAILER (A58375)
HOMEMADE JOHN...
New/Unused Mini Skid Steer Attachment Set A (A57454)
New/Unused Mini...
