RadarTech
Elite Member
If it is that rough and painful, why not use a pulverizer or similar and smooth it? If it’s beating you, how bad is it on the equipment?
It is a time issue. I am the only one maintaining nearly 100 acres so there is always something urgent elsewhere.If it is that rough and painful, why not use a pulverizer or similar and smooth it?
Maybe identify the worst parts and do them and just little each spring and fall…It is a time issue. I am the only one maintaining nearly 100 acres so there is always something urgent elsewhere.
It was planted with some sort of grass/plant about 60 years ago. The pasture is pretty uniform in growth, except a draw where a lot of water comes through. It first comes in beautiful green, grows rapidly, then dies off to brown as the season wears on. I don't irrigate except for a strip near the pond.
I was also concerned that doing too much smoothing in summer or fall might chew up the land leading to patches of weeds.
That is a really good plan.Maybe identify the worst parts and do them and just little each spring and fall…
It does go bad if exposed to air. I would purchase a small harbor freight type of suction pump and pull it out and fill with fresh fluid if its really old.Its purring like a kitten in our shop. I still haven't had to add def fluid, that's how little I drive it, hope it doesn't get old in the tank.
However The service antilock brake system light has been flashing on and off....
There should e a recall on those, I hear a lot of them are failing.
One thing that don't concern me is equipment cost because it's all a business write off anyway. I don't even consider finance rates when buying equipment either because that is an offset as well. Why I never buy used stuff. Used hay tools are just that, used and mostly abused and I don't want to buy someone else's issues.If you're only cutting this 2 or even 4 times a year you could get a lot of years paying someone to do it for you for $38,000. And you wouldn't have to worry about finding time to do it. Just say $500 a time at 4 times a year and that covers 19 years........
Your use of common sense is getting in the way of me wanting to have a new piece of equipment!!!!If you're only cutting this 2 or even 4 times a year you could get a lot of years paying someone to do it for you for $38,000.
I cannot deduct the cost of equipment, but I do believe purchasing such items is a good investment in these times. Some would throw tomatoes at me for saying that, but every piece of equipment (except for a brand new cab tractor) is now worth more than what I paid for it. And the cab tractor might be close to original price.One thing that don't concern me is equipment cost because it's all a business write off anyway.
Go for it, enjoy it while you can. Whether it is money or equipment, you can't take it with you. I have never seen a loaded hearse headed for the cemetery pulling a U-Haul.Your use of common sense is getting in the way of me wanting to have a new piece of equipment!!!!
Good post ....
The only mower that will do 5 ft weeds is a brush cutter / brush hog and it will not look like a lawn afterwards. I've never had the chance to try out a 48hp Ferris but that's gotta be an awesome machine. But I don't think it'll cut 5 ft high weeds. What does the dealer say about it ? He might know what the capability is.
What do you like about the flail vs brush hog?Brush hog will work in tall grass & weeds, however in my experience flail mower works also good - I think little better,
Go for it, enjoy it while you can. Whether it is money or equipment, you can't take it with you. I have never seen a loaded hearse headed for the cemetery pulling a U-Haul.![]()
btw my brush hog is at max limits for my tractor-- 8ft connected to 44hp at the pto. Between the tractor tires and the trailing wheels on the brush hog there are certainly a lot of bumps.
I considered a flail mower some time ago with an articulating side arm so I could also mow the edge of the bank at the pond ...
- No scalping at all when set up right. Uneven forested area is a prime example.
- Chops the tall pasture or field grass finer leaving a nicer look
- Uses less power - comparing 48" JD 413 vs. 60" Ford 917L (side slicer flails).
- Can mow given area faster due to width difference.
- Takes less space to store.
My Ford 1310 tractor has 1L 19 hp engine (12 speed manual transmission) so it's pretty easy to notice the difference in power usage.
