Can a Zero Turn mow high weeds in a bumpy pasture?
   / Can a Zero Turn mow high weeds in a bumpy pasture?
One thing that don't concern me is equipment cost because it's all a business write off anyway.
I cannot deduct the cost of equipment, but I do believe purchasing such items is a good investment in these times. Some would throw tomatoes at me for saying that, but every piece of equipment (except for a brand new cab tractor) is now worth more than what I paid for it. And the cab tractor might be close to original price.
I lived through the Carter "stagflation" years of the 80's, which is sort of similar to today. I don't want to touch off a political debate, but I have no problem trading "declining value greenbacks" for equipment that is only getting progressively more expensive.
But -- a $38k diesel mower might blow a hole through all of this ... 😃
   / Can a Zero Turn mow high weeds in a bumpy pasture? #52
Your use of common sense is getting in the way of me wanting to have a new piece of equipment!!!! 😃
Good post ....
Go for it, enjoy it while you can. Whether it is money or equipment, you can't take it with you. I have never seen a loaded hearse headed for the cemetery pulling a U-Haul. :D
   / Can a Zero Turn mow high weeds in a bumpy pasture? #53
The only mower that will do 5 ft weeds is a brush cutter / brush hog and it will not look like a lawn afterwards. I've never had the chance to try out a 48hp Ferris but that's gotta be an awesome machine. But I don't think it'll cut 5 ft high weeds. What does the dealer say about it ? He might know what the capability is.
Brush hog will work in tall grass & weeds, however in my experience flail mower works also good - I think little better, but requires little more maintenance!
I have a John Deere 413 brush hog and 5' Ford 917L Special with side slicer flails.
Have not used the brush hog hardly any since I got the flail mower.
What do you like about the flail vs brush hog?
btw my brush hog is at max limits for my tractor-- 8ft connected to 44hp at the pto. Between the tractor tires and the trailing wheels on the brush hog there are certainly a lot of bumps.
I considered a flail mower some time ago with an articulating side arm so I could also mow the edge of the bank at the pond ...
   / Can a Zero Turn mow high weeds in a bumpy pasture? #55
Flails chop the biomass finer, leaving a neater cut IMHO
   / Can a Zero Turn mow high weeds in a bumpy pasture? #56
Once you do it once, you can keep it mowed down with a ZT. I mow my VA lot, about 3 acres of grass with my ZT. It was a hay field previously, now it looks like a park. I mow it once a month, takes about 2 hrs.
   / Can a Zero Turn mow high weeds in a bumpy pasture? #58
  • No scalping at all when set up right. Uneven forested area is a prime example.
  • Chops the tall pasture or field grass finer leaving a nicer look
  • Uses less power - comparing 48" JD 413 vs. 60" Ford 917L (side slicer flails).
  • Can mow given area faster due to width difference.
  • Takes less space to store.
My Ford 1310 tractor has 1L 19 hp engine (12 speed manual transmission) so it's pretty easy to notice the difference in power usage.
   / Can a Zero Turn mow high weeds in a bumpy pasture? #59
^^^ 👍. I’ll add that I find it’s less ‘jolting’ on me than my bush hog. It rides gracefully on the 6’ wide rear roller close in vs. a small tail wheel dipping into holes & flipping around on turns.
   / Can a Zero Turn mow high weeds in a bumpy pasture? #60
The flail mower roller smooths out the gopher mounds nicely
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Autocar Xpeditor T/A Heil Front Loader Garbage Truck (A59230)
2017 Autocar...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2013 VOLVO EC250DL EXCAVATOR (A60429)
2013 VOLVO EC250DL...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
