Can a Zero Turn mow high weeds in a bumpy pasture?
   / Can a Zero Turn mow high weeds in a bumpy pasture?
One thing that don't concern me is equipment cost because it's all a business write off anyway.
I cannot deduct the cost of equipment, but I do believe purchasing such items is a good investment in these times. Some would throw tomatoes at me for saying that, but every piece of equipment (except for a brand new cab tractor) is now worth more than what I paid for it. And the cab tractor might be close to original price.
I lived through the Carter "stagflation" years of the 80's, which is sort of similar to today. I don't want to touch off a political debate, but I have no problem trading "declining value greenbacks" for equipment that is only getting progressively more expensive.
But -- a $38k diesel mower might blow a hole through all of this ... 😃
   / Can a Zero Turn mow high weeds in a bumpy pasture? #52
Your use of common sense is getting in the way of me wanting to have a new piece of equipment!!!! 😃
Good post ....
Go for it, enjoy it while you can. Whether it is money or equipment, you can't take it with you. I have never seen a loaded hearse headed for the cemetery pulling a U-Haul. :D
   / Can a Zero Turn mow high weeds in a bumpy pasture? #53
The only mower that will do 5 ft weeds is a brush cutter / brush hog and it will not look like a lawn afterwards. I've never had the chance to try out a 48hp Ferris but that's gotta be an awesome machine. But I don't think it'll cut 5 ft high weeds. What does the dealer say about it ? He might know what the capability is.
Brush hog will work in tall grass & weeds, however in my experience flail mower works also good - I think little better, but requires little more maintenance!
I have a John Deere 413 brush hog and 5' Ford 917L Special with side slicer flails.
Have not used the brush hog hardly any since I got the flail mower.
What do you like about the flail vs brush hog?
btw my brush hog is at max limits for my tractor-- 8ft connected to 44hp at the pto. Between the tractor tires and the trailing wheels on the brush hog there are certainly a lot of bumps.
I considered a flail mower some time ago with an articulating side arm so I could also mow the edge of the bank at the pond ...
   / Can a Zero Turn mow high weeds in a bumpy pasture? #55
Flails chop the biomass finer, leaving a neater cut IMHO
   / Can a Zero Turn mow high weeds in a bumpy pasture? #56
Once you do it once, you can keep it mowed down with a ZT. I mow my VA lot, about 3 acres of grass with my ZT. It was a hay field previously, now it looks like a park. I mow it once a month, takes about 2 hrs.
   / Can a Zero Turn mow high weeds in a bumpy pasture? #58
  • No scalping at all when set up right. Uneven forested area is a prime example.
  • Chops the tall pasture or field grass finer leaving a nicer look
  • Uses less power - comparing 48" JD 413 vs. 60" Ford 917L (side slicer flails).
  • Can mow given area faster due to width difference.
  • Takes less space to store.
My Ford 1310 tractor has 1L 19 hp engine (12 speed manual transmission) so it's pretty easy to notice the difference in power usage.
   / Can a Zero Turn mow high weeds in a bumpy pasture? #59
^^^ 👍. I’ll add that I find it’s less ‘jolting’ on me than my bush hog. It rides gracefully on the 6’ wide rear roller close in vs. a small tail wheel dipping into holes & flipping around on turns.
   / Can a Zero Turn mow high weeds in a bumpy pasture? #60
The flail mower roller smooths out the gopher mounds nicely
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
205196 (A52706)
205196 (A52706)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A59231)
2009 Mariah SC23...
