LightningCamaroGuy
Gold Member
- Joined
- Dec 31, 2016
- Messages
- 309
- Tractor
As a tool maker/die builder I can safely say that I dig it. Very cool, and nice work OP. Look forward to seeing the finished product.
Whats the plan with this hinge, do you want to tilt the cutter head a bit to provide controlled depth of cut, without using the tractor gears ?
I hope for you that it works the way you envision. A chainsaw has depth gauges, preventing the chisels from biting too much and stalling the engine. I dont have experience with stump cutters, but i would rather have a slip clutch in the PTO shaft as driveline protection, and have the cutter assembly as rigid as possible. Also, your link arm stabilisers would need to be very tight or it will rock left to right whenever you engage a stump.The idea is the hinge allows the cutter to swing away (actually hold position) if the tractor moves and the cutters can’t cut that fast, then the operator stops advancement and lets the chipping head cut until it’s back vertical.
That one looks like a toy compared to what the OP is fabricatingMany small grinders are designed with the forgiving swing away feature. There are several 3pt makes and skidsteer ones too. I like how the OP is adding heft to his as that should help with it hopping while cutting...good job and keep us up to date.
No kidding! Pretty wimpy compared to what we are watching being built.That one looks like a toy compared to what the OP is fabricating
Very interesting !! I have been thinking about building it simple like that, but thought it wouldnt work. All stump grinders here in Europe are heavy duty commercial ones with outriggers for a firm stance.Many small grinders are designed with the forgiving swing away feature.
I am just not sure when i build one, do i want it like this, super simple, or do i want one with an angle gearbox, which i can rotate 90 degrees so i can also use it as a tree saw, cutting at ground level without dulling my chainsaw in the dirt... it would be really cool if i could just run over things backward, for fencerow cleanup.
In reality, quality tungsten carbide teeth will deal with rocks pretty well.I wasn’t either, the first one I built, years ago now, was another scrap build that was a side to side swinging one but manual. It works but is a lot of work or I am too old.
I built it when I was given this cutting head.
Used an old brigs 8hp engine that I threw and electric starter on, the go kart brake on the axle is so you can throw a lever on the tiller handle bars, locking that wheel, making it easy to swing the arch.
Battery up front for weight over the cutting head.
I will say this, that one takes up more floor space in a barn than this one will, if that’s important.
I wouldn’t be too worried about dirt but our place has lots of rocks and gravel. So I threw This trailer together so I can blow them away from the stumps, so I can get them below grade.
View attachment 839032View attachment 839019
It’s work too but I imagine the teeth last much longer just hitting wood.
I’d trade for one of these though.
What is your background, if i may ask ? Auto or aircraft environment?I torqued everything down,
I am curious as to price on the cutters, knowing that carbide is not cheap !
