Power Rake build
/ Power Rake build #21
Is there any reason to choose a Lovejoy setup vs Universal joint?
I can get either setup for about the same cost. The LJ would add a bit of cushioning during startup vs the solid connection of the UJ.
The Lovejoy coupling you picked out will not handle the load. Your tractor has about 18 PTO HP. At 540 RPM, 18 HP is 175 lb-ft of torque. The coupling is only rated 680 in-lbs or about 57 lb-ft.
The universal joint has a high enough rating, but the thing with a universal joint is that you need two joints to handle both axial and angular misalignment. Two joints also maintain constant angular velocity. You would still need a second bearing to support the shaft near the sprocket.
I see Surplus Center has some 60 pitch roller chain couplings that will handle the torque, but are only rated for 500 RPM. Also, I do not see a cover for the 60 pitch chain couplings so you have to ask them as you would need a cover to keep the dirt out.
Are you planning on a slip clutch or shear pin in the PTO shaft?
/ Power Rake build
I am not really familiar with those chain couplers, they will be able to handle the varying angles?
I looked at the 60 pitch couplers and it says that they are rated to 3000 RPMs.
1" BORE 60 PITCH 18 TOOTH CHAIN COUPLER HALF
And they do have the covers for them as well.
60 PITCH 18 TOOTH COUPLING COVER
And I have a slip clutch for the PTO shaft.
Thanks for your help. :thumbsup:
/ Power Rake build #23
Hi Zick,
You are entirely welcome, I meant it.
The other thing is that I am learning as least as much and probably more than you are from the others posting and I really appreciate that as well.
Thomas
/ Power Rake build #24
Stonehauler,
Please excuse my ignorance, but if the rating listed on Surplus Center states that the max power rating is:
"Power 39.6 Hp max @ 3600 RPM" is it really necessary to look at the max torque too?
It is the start-up toque to get it to that RPM that is the issue?
Thanks, and sorry Zick for the thread co-op, but I didn't understand why there are separate listings for the two ratings, as Stonehaller seemed to be using your HP and RPM's to figure out your torque figure...
Thanks again,
Thomas
/ Power Rake build #25
Oops, I missed that there were multiple pages. That coupling you picked is plenty big enough. Chain couplings can handle both angular and axial offset (parallelism or eccentricity), but your shafts have to be pretty close. They are not like universal joints. You probably need to get your shafts within about 0.015" and 1 degree angularity.
Lovejoy also makes larger jaw couplings. A Model L110 with a Hydrel spider can handle 189 lb-ft of torque up to 1750 RPM. Their misalignment capability is similar to the chain couplings. I would expect the love joy is more expensive than the chain but you may want to do a search to check it out.
If you have enough room, you could use the universal joints as well. Another thing about universal joints is that you want some off set in your shafts so the bearings in the u-joints will turn. You could just put a spacer under your gear box so that the u-joints run at 1 or 2 degrees. The nice thing about the u-joints is you do not have to mess around trying to get the gear box precision aligned to the shaft.
Stonehauler,
Thanks again,
Thomas
It is important to consider torque when sizing drive line components. Horsepower alone does not give you enough information. You need horsepower and velocity or torque and velocity. The torque rating for couplings is generally constant over the RPM range. 39.6 HP at 3600 RPM is 57.7 lb-ft of torque. That same torque at 540 RPM is only 5.9 HP - much less than the tractor can do. Here's the formula to calculate torque in lb-ft from HP and RPM: Torque (lb-ft) = (Horsepower x 5252) / RPM.
/ Power Rake build
So due to some personal issues and my crappy Clarke welder dying (Think it's just a relay but I can't find anyone that stocks it), I am behind schedule.
Had to take everything out to my father in laws and use his equipment. Though I'm not really complaining since he has much nicer stuff that I have. :cool:
Like everyone said it would, this took forever! Probably about 8 hrs worth :grumpy:
Setting up the gauge wheels.
Finishing up on the angle mechanism.
Still need to setup the chain idler gear and figure out a cover for it. Then the fun part, taking it all apart again and painting it. :tired:
/ Power Rake build #27
:thumbsup: looks like a gooder-un.
/ Power Rake build #28
Good progress, thanks for keeping us updated!
/ Power Rake build
Big update!
Worked on it slowly over winter but finally got it done enough to try out. Seemed like all those little things took longer to get done than the bigger stuff.
Getting the chain coupler setup and installed. May or may not be the best place to put it but I didn't know any better. :confused3:
Test run inside. Click on pic to play video.
Temp cover to keep an eye on things until I can make up a final cover.
After using for about 3 hours.
Results: It worked excellent and better than I hoped! :hyper:
But there are a few things that I need to address before I can use it again.
The gauge wheels (8" what I had laying around) are probably a too small. They worked OK but bigger and wider wheels would be better. The wheel arm is way too short. I can't put the wheels down far enough to get the wheels to hold the rake because they get too close to the teeth and will actually hit. :eek: Plus, at that angle the wheels don't track well. So I'll probably extend the arm out another 1ft and maybe upgrade the wheels.
The gauge wheel c channel bracket that holds the top link to the wheel arm is way too weak, it flexes really bad and I bent it when I tried to back into a hill :ashamed:
So that will probably get boxed in for strength.
And now for the bad part. After about 3 hrs of use, I heard something and found the drum wasn't spinning anymore. I saw the chain had came off so I took over the cover to investigate and found this.
And this, the sprocket took some damage too.
I managed to fix the chain and clean up the sprocket enough to probably re-use. Got plenty of chain so if it messes up the chain I'll replace the sprocket.
I found that the set screws on the pillow blocks holding the drum must have vibrated loose and allowed the drum to shift over which threw of the chain alignment.
I'm going to see about finding some kind of sleeve to fill up the gap between the drum and side pillow blocks so it can't move side to side anymore.
/ Power Rake build #30
Glad it worked well and you can fix the problems. :thumbsup:
On the gauge wheels, casters need to be level, so you could cut where I put the arrows extend slightly and change the angle to make them level when down.
If level they will be farther from the drum.
/ Power Rake build #31
Could you not make the trailing wheels at a fixed height on the machine and use the tractor's top link to angle the whole machine and thus change the drum height? This would allow you to change drum height from the tractor seat too. (BTW, I love this build, I want one!)
/ Power Rake build #32
I had an idea of making one years ago when I was much younger. I had a Cunningham hay crimper
(but guess any brand could be used) that would have most of the components ready made and
very heavy duty,gear box,shear pin,drum and heavy duty bearings that would take the pressure.
This unit had a fiber that tightened the chain instead of an gear this worked well and was under a
lot of stress.Just my idea but I think it would work without a lot of expense and few changes.
Something to think about for those planning to make one W.C.W.
/ Power Rake build #33
That came out really nice, looks professional! After the tweaks you're planning it'll be pretty bullet proof I'll bet. :thumbsup:
/ Power Rake build #34
You will get thrust load on the drum whenever you turn with the rake engaged in the ground. There is probably thrust load even when going straight as the drum teeth will not be perfect and the ground is never uniform. You can get pillow block bearings with eccentric locks that are much better for holding the shaft than just a set screw in to the shaft. Ideally, you want to lock the shaft on the sprocket side so you could replace just that bearing with one with the eccentric lock.
If you would rather uses spacers on the shaft, then if your clearance hole through the chain box is large enough to get a spacer through to contact the inner race of the bearing then you could put spacers on both sides of that bearing. You would need three spacers, one between the bearing and the drum, one between the sprocket and the bearing and one between the sprocket and the end of the shaft. Have the last one extend slightly beyond the end of the shaft. Drill and tap the center of the shaft and use a bolt with a hardened washer or several fender washers (so they don't flex under the bolt load) to tighten the spacers together. Leave the sprocket loose until you tighten the bolt and then tighten the sprocket.
The simplest way is to just put two spaces on either side of the drum between the bearings as you suggested. You will still get some movement of the sprocket with this method, but I expect it will be small enough for the chain to handle. Lock the spacers to the shaft so they will not be able to spin against the bearing race and wear the spacer.
/ Power Rake build #35
To keep the rake from throwing all that trash upon the machine, you might add a mudflap just ahead of the roller. My factory rake just had a piece of angle welded across the front with some conveyor belt bolted to it. Come to think about it, big rocks kept getting hung up in the flap and breaking it off, so maybe not such a good ideal.
/ Power Rake build
Thanks guys for the suggestions, I got some ideas to think about now.
:drink:
/ Power Rake build #37
Great project. Inspiring and nice construction. Thats a lot of welding, bet you had to take a rest.
I was wondering why you chose a single spiral and not two self opposing spirals. In operation does it seem to thrust (when driving straight forward) ? Or can you feel a difference in thrust turning left as opposed to turning right?
/ Power Rake build
Lack of planning...:ashamed:
In hindsight it would have probably been better to build it like you described but luckily it doesn't seem to pull while in operation. If it does it's not enough for me to notice yet.
Oh and I've got to get some new pictures. I reinforced the upper gauge wheel mount and put on much larger wheels. The larger wheels alone made the casters sit almost level so they track better. I haven't extended the wheels out further yet because it seem to be working better now but I still may add 6-12" later down the road.
/ Power Rake build #39
It does seem like each vane, encountering virgin soil on its left, and perhaps shattered soil on its right, would tend to thrust (some).
Opps! Broke one of the cutters. Hougen was nice enough to send me a replacement.
I like those Hougen cutters. I've broken a couple and Hougen declined my offer to receive replacements. Hougen said what breaks the cutters is trying to cut deeper (thicker metal) than the cutter is deep. When the cut is gets to its depth limit it can no longer eject the chips. So they remain inside the cup, pack up and explode the cup. Which was is exactly how I broke both of mine. I had to buy a replacement "set of three".
Now if I drill near the full depth I proceed very slowly near the limit, clearing chips often. You can carefully use the next size smaller cutter (in the same centerpunch) to create some chip clearance. Or drill a small locating hole on thru then use the annular cutter from both sides.
But anyway congrats on the implement. I like to see what members are building.
What is the general purpose of this implement? To level soil? To mulch vegetation?
/ Power Rake build
General use for it right now it to level the yard, after that who knows. :cool:
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
(2) SUPER SAVER HEATERS & PARTS (A64278)
(2) SUPER SAVER...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
JOHN DEERE 7320 TRACTOR (A64278)
JOHN DEERE 7320...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
