Battery powered chainsaw
/ Battery powered chainsaw #561
I can second that. Kombi KM 131 R engine, with bed redefiner, string trimmer, hedge trimmer, pole saw, and a smattering of extensions. Very useful bit of kit for getting done just about anything around the house.
A pole saw can also be useful for cutting branches under high or unpredictable loading, from big blown-down trees, while keeping you a few feet outside the firing zone. I've known more than one case of someone getting taken out by such scenarios, being too close to the work, when pressure released differently than predicted or expected.
And that pole saw like on the Kombi is far, far less heavy and is user friendly that those extendable types.
/ Battery powered chainsaw #562
Storm damage clean up is one of the more dangerous aspects of working in the woods - at least if you are working without the benefit of large machines. It's time consuming, and a lot of those pressures can be hard to read.
/ Battery powered chainsaw #563
Twice I have walking in heavily forested areas on calm as could be sunny day and one a very tall tree about a 100 feet just fell over… it did have a little lean and another time in similar conditions the entire top half keeled over…
/ Battery powered chainsaw #564
I have a widow maker on the side of one of my main trails. A scaley bark hickory snapped off about 40' up the main trunk, but is still hinge connected to the lower trunk. The top is almost touching the ground. Still debating how I am going to pull that one down. I really dont want to connect onto the tree on the main trail with my tractor. I thought about weaving my tractor into the woods and start pulling on the bottom of the top section about 50' away into the woods. When it comes down and bounces in my direction, I would have the rest of the trees to shield it from possibly hitting me. Plus, at 50' out, that should be longer than the broken section.
/ Battery powered chainsaw #565
Maybe a picture or two?
I had a tree break here way up high, puzzled over it, then in brought it down with five 12ga slugs in a row across split.
/ Battery powered chainsaw #567
I'm not up for all day land clearing, but once I have logs piled up for bucking I can run through several tanks getting them short. Now the splitting requires a break after every tank of fuel.
Just the opposite here. I'm ready for a break after one tank of cutting up, but for me splitting is a piece of cake. Then again, a tank lasts a lot longer in the splitter than with the saw.
/ Battery powered chainsaw #568
We don't heat with wood, never have so all the trees I cut down get cut into saw logs and piled up next to the barn and I have a friend in the campground firewood business, so I load his GN trailer with the saw logs and he processes them. I always have a pile of saw logs here for the taking, most all hardwood as well. Small stuff gets roasted (under 3" diameter).
/ Battery powered chainsaw #569
Re battery pole saws, I have a lot of Ryobi 18volt shop stuff so I bought the matching pole saw.
Don't.
It cuts ok, slowly, but adding the extension wand feels so flimsy that it feels like just leaning into the work to cut faster could snap it off. Reviews I've read verify this is a real problem.
Buy something else.
And in contrast to this, the Ryobi 18 volt chainsaw is fine for light work. Nearly all of my use is removing dead limbs or bucking hollow trunks in my apple orchard and its fine for that. Heaviest thing I've cut with it was a 10 inch eucalyptus (tough!) that fell across a haul path and I thought this might smoke it but that didn't hurt it any. It's no match for a gas saw but its a good match to what I need.
/ Battery powered chainsaw #570
KY EXPO has a new greenworks 82v for the landscapers and homeowners etc. Greenworks Revolutionizes the World of Chainsaws with the First Ever H.O.G. Saw
/ Battery powered chainsaw #571
Maybe electric saw in my future if that thing is that good.
/ Battery powered chainsaw #572
Did they say how much it would cost?
/ Battery powered chainsaw #574
At least they have the sense to bill it as a "landscape saw".
$600 for their “65cc equivalent” and it weighs 17.3 lbs (including a 4 AH battery. The new saw comes with a larger battery.)
Have not seen price or specs on the new H.O.G. saw that is supposed to be 72cc equivalent.
/ Battery powered chainsaw #575
Looks interesting, would like to try one
/ Battery powered chainsaw #576
Too heavy for me to want to lug around in the woods all day, but I see they are marketing it as a “landscaping saw”. I suspect that application is typically less of a “use it all day” scenario.
I’m glad to see the industry is making progress.
/ Battery powered chainsaw #577
I have a generator I could set in bed of truck. Maybe I should have bought this...$95...very light...no batteries. Just don't cut the cord!
/ Battery powered chainsaw #578
Or go whole hog and get a;
2019 CATERPILLAR 299D3 SKID STEER (A65053)
2019 CATERPILLAR...
KING 3 BAR - 18 SHANK CHISEL PLOW, 3PT (A64278)
KING 3 BAR - 18...
2020 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2017 Nissan Titan Crew Cab Pickup Truck (A64556)
2017 Nissan Titan...
Ford Pickup Truck Bed (A64556)
Ford Pickup Truck...
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
