Battery powered chainsaw
/ Battery powered chainsaw #601
I'm more interested in the newer Echo lightweight saws... The battery saws are just so damn heavy
/ Battery powered chainsaw #603
These are limbing saws and gosh they are good for lighter cut. We carry them via 6x6 or backpacks all the time now. I was late to game for tree tools battery powered. I have two of there now. Seen here with twine locking up the chain!
/ Battery powered chainsaw #604
Both a blessing and a curse, if the push to go battery wasn't there, the saw companies would not be making the effort, but it has reduced the number of companies working n enhancing gas saws.
I have been mostly happy with my Milwaukee battery products.
I want to try one of their saws, but with 2 ice and the one battery pole saw, the investment need is not there. Would be nice to have a lighter saw though than my 490 or 620 Echos.
I see Milwaukee rolling out a next generation battery in the M18 Fuel series, waiting to see reviews before spending as batteries are big $ items.
That's where I'm at too.
I was seriously looking at getting a battery saw 14-18" range recently because my smaller gasser was being a PITA in many way, but now that I got that sorted out I can probably give the market a few more years before I reconsider.
Considering the extra weight that battery saws seem to have right now compared to a gas of (really) the same power, it doesn't seem like no-brainer to switch, especially as the fatigue from a few extra pounds could lead to serious injury. Still it would be really nice to have a battery saw in my truck...
/ Battery powered chainsaw #605
Photo - toughest thing I've cut with the little Ryobi 18v chainsaw. Eucalyptus, green, tough! After this cut I made one more cut back where it was a little larger. I'm re-opening access into this terrace in the orchard.
I thought running it this hard might overheat it, but no problems, no heat or smell. I have a second new motor (less bar) that I found for $10 at Goodwill so I'm not risking much if I have to run it hard again.
I don't recall that it ever stalled in this project.
This isn't as fast as a gas saw but its well matched to what I need, for orchard pruning in soft Apple wood.
kimg1634rsawdowned-eucalyptus-jpg.474385
Incidentally, this saw stops the instant I let go of the trigger. There's no inertia.
/ Battery powered chainsaw #606
Note to self… be extra careful with the corded Stihl chain saw.
I bought it just before the battery stuff started coming out… good saw for sure but doubt I would have bought it had I known how much I can do with the battery Stihl…
I too bought a Stihl corded chainsaw. On a big discount just before the battery craze hit. I use it often at the building on quick cuts and in the yard. It's powerful. Always starts, LOL.
I wouldn't mind having a battery top handle but by the time the charger and two batteries are added, whew....
/ Battery powered chainsaw #607
When I spoke with Greenworks they said, of course, the lower AH battery the lighter weight...like 2AH vs 5AH. 5AH gives more cutting time though.
/ Battery powered chainsaw #609
I don't think anyone was making battery saws because they thought the government wanted them to.
Just as no one made battery drills because the government wanted them to.
Darn creative Capitalist Pigs saw a market and pursued it. I bought an EGo 18" chainsaw because it best suited my needs. Am not a professional landscaper or logger. An EGo 56v string trimmer is also perfect for my use.
/ Battery powered chainsaw #610
Well, there's this:
The law, signed into effect in October, directs the California Air Resources Board (CARB) to create rules banning the sale of new gasoline-powered lawn tools, including mowers, handheld equipment and any new gas-powered equipment using small off-road engines, by 2024, or whenever feasible.
/ Battery powered chainsaw #611
/ Battery powered chainsaw #612
And which came first the chicken or the egg?
In this case the battery tools were there before a government decided to make them mandatory.
Good point, at least your second sentence.
The first one is easy though... the egg. I'm not sure what the hell kind of pre-historic chicken ancestor laid it, but the first chicken came out of an egg.
/ Battery powered chainsaw #615
Is this possible?
I don't think so. I just ran out to the shed and grabbed my very well-tuned Stihl 036 Pro off the shelf. This is a saw that usually starts on second pull from dead cold, and first pull thereafter. Here's what I did:
  1. Set multifunction lever to full choke, pressed decomp valve, drew cord out and released. Nothing.
  2. Repeated second time. Nothing.
  3. Gave the pull cord the usual yank, fired right up.
  4. Warmed up the saw a few seconds, shut it off. Set multifunction lever to warm start position, yanked the cord, started right back up. Repeated two more times, to verify consistent one-pull starts.
  5. Repeated trick in video three more times, with multifunction lever set to warm start position, nothing. No start.
  6. Gave the cord a quick yank, fired right up, as it should.
Saw is good, video is a hoax, or maybe only applicable to very specific models.
/ Battery powered chainsaw #618
Speaking of starting saws and decomp valves, I always get a kick of watching people try to start my 064 AV. It's 85cc at 110 psi, and will yank your shoulder half out of its socket, if you don't fully-commit to the cord pull. Most people try it once, and hand it right back. :ROFLMAO:
/ Battery powered chainsaw #619
I have a husky 2100 that needs a full wrap around pull cord to start.
/ Battery powered chainsaw #620
Yeah, that's a real saw. Keeps the faint of heart from having a go at it. :p
"You can't start it? Then you can't run it!"
I ran an 084 for a short time, before trading it in on the 064, something like 135 cc. Like putting a bar and chain on a motorcycle engine.
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2000 INTERNATIONAL 9200 DAY CAB (INOPERABLE) (A65643)
2000 INTERNATIONAL...
3097 (A63117)
3097 (A63117)
2019 ISUZU NPR 16FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 ISUZU NPR...
master diesel generator (A64553)
master diesel...
