milwaukee battery 1/2" impact question
/ milwaukee battery 1/2" impact question #43
Hum - you are using a impact wrench to torque the lug nuts on your cars wheels ?
Not a good practice.
I just did the spring tire change over on 3 vehicles using my Milwaukee M18 1/2" removing the lugs and installing them using a torque stick it didn't even take the battery down enough to put it on the charger.
Of course I also use never sieze on the wheel studs and the hubs and rims.
/ milwaukee battery 1/2" impact question #47
It is said not to use a torque stick, or at least rely on it- especially with a non pneumatic impact. One probably shouldn't ever rely on them I guess. That being said, I do the same sans the never seize. Then a walk around with the big T.
/ milwaukee battery 1/2" impact question #48
Because I do use lubricant I use a bit less then the recommended torque on my pickup 110# versus the called for 130# Iv'e verified the results with a torque wrench a few times and it has been quite good.
The last tire I've had come loose was back in the late 80's from a tire shop.
/ milwaukee battery 1/2" impact question #49
I don't own a torque wrench. I rotate all my vehicles tires/wheels. I use a pneumatic gun, no torque stick. I've never lost a tire/wheel. I use the "rat a tat tat tat" method. :)
/ milwaukee battery 1/2" impact question #50
You are playing with fire old man.
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2013 Ford Escape SUV (A59231)
2013 Ford Escape...
2003 IC Corporation 3000IC School Bus (A59230)
2003 IC...
2005 Nissan Frontier Crew Cab Pickup Truck (A59230)
2005 Nissan...
Volvo L45H (A61307)
Volvo L45H (A61307)
Kubota L4701 (A53317)
