two_bit_score
Super Star Member
- Joined
- Dec 22, 2008
- Messages
- 12,601
- Tractor
- John Deere 110 TLB, Diamond C 19LPX GN trailer
Absolutely no reason not to.I skipped over it and bought the newer model. Cost me an extra $20.
This picture really kicks my OCD into high gear.
I just did the spring tire change over on 3 vehicles using my Milwaukee M18 1/2" removing the lugs and installing them using a torque stick it didn't even take the battery down enough to put it on the charger.Hum - you are using a impact wrench to torque the lug nuts on your cars wheels ?
Not a good practice.
Should have lined the drills up to match the separation joint in the curb.Cool ain't it!!!
It is said not to use a torque stick, or at least rely on it- especially with a non pneumatic impact. One probably shouldn't ever rely on them I guess. That being said, I do the same sans the never seize. Then a walk around with the big T.I just did the spring tire change over on 3 vehicles using my Milwaukee M18 1/2" removing the lugs and installing them using a torque stick it didn't even take the battery down enough to put it on the charger.
Of course I also use never sieze on the wheel studs and the hubs and rims.
You are playing with fire old man.I don't own a torque wrench. I rotate all my vehicles tires/wheels. I use a pneumatic gun, no torque stick. I've never lost a tire/wheel. I use the "rat a tat tat tat" method.![]()
I did the same thing with steel wheels way back when. But with todays light weight materials the rims are made of, I like to use some method of verification.I don't own a torque wrench. I rotate all my vehicles tires/wheels. I use a pneumatic gun, no torque stick. I've never lost a tire/wheel. I use the "rat a tat tat tat" method.![]()
Only takes ONE time. Richard. I run them on with an impact but the final torque is always with a torque wrench and... I'll drive them around the block and check them again.Been driving for 55 years. Have no idea how many tires I've changed.
Yee of little faith. I've never one time in my life tightened a wheel lug, drove around, and retightened. Not once.Only takes ONE time. Richard. I run them on with an impact but the final torque is always with a torque wrench and... I'll drive them around the block and check them again.
Beam wrenches have been around since I was a kid and Im, 73. You must be really ancient..... lolI use a long breaker bar to loosen the lugs and spin them off with a 1/4" impact and then the reverse to install. Just use "feel" to tighten and rarely use a torque wrench. When I first started driving and fixing, a torque wrench was an exotic tool only used for major repairs.
Haa....that woulda been nice, but no such luck. Just reading the replies. Im leaning toward the mid torque honestly as it is considerably lighter and should do all i need since my air impact always has. Still not 100% sure thoughI don't see where the OP has chimed back in. He may just be waiting to see if his wife puts one of them in his Easter basket...
