The last Barn. (maybe)
/ The last Barn. (maybe)
I did post the first tank in another thread but this belongs in this thread.
I have always wanted my own fuel tanks and I finally have them. One has summer diesel fuel in it, the other one will have winter diesel. I have the strap on it because winter fuel is not available yet and I don't want to take a chance of the wind blowing it off the stand.
They are both 550 gallon tanks.
/ The last Barn. (maybe) #163
A band around them is not a bad idea either way.
/ The last Barn. (maybe) #164
I use 1700-2000 gallon of diesel per year. I need to do this.
Good stuff Lynn.
/ The last Barn. (maybe) #166
Richard I bought these tanks from Wemac right there close to where you live. Most of the cost was shipping.
I'll check it out. Thanks Lynn!!!
/ The last Barn. (maybe) #167
Nice as always really enjoy watching your projects unfold
I am finally starting to fill my wood area in the barn. I have lots of work ahead of me. Hoping to get it all inside before snow starts.
First time using a log splitter and all I can say is "why didn't I buy one sooner."
/ The last Barn. (maybe) #170
Are you buying your logs from a logging company? Is that pine?
/ The last Barn. (maybe) #172
I found using my splitter vertical was MUCH easier on my back. Does yours rotate for that?
You should also NOT run the motor inside your building (even with the "doors open")...
I have raised the splitter up about 5" and my back feels much better using it now.
As to the running it inside; we generally have a constant breeze from the back of the barn to the front. I definitely thought about CO poisoning but I feel confident that the breeze is enough to keep us breathing good air.
/ The last Barn. (maybe) #176
I'm on the fence about vapor barrier. I think there's a lot of logistical variances that come into play.
If I were building this in Missouri I wouldn't put a vapor barrier down.
Why no vapor barrier in MO. I would have thought it was needed here...
/ The last Barn. (maybe) #177
I don't think location dictates a vapor barrier or not as much as usage.
There's a lot of disinformation concerning plastic vapor barriers. The biggest is that the plastic will keep ground water from coming thru the concrete......
If the building is somewhat climate controlled there will be no condensation on the floor. It happens when the floor temp and the air touching the concrete have a large temp difference. Simple condensation.
I'm on my 3rd shop. All three are/were heated in the Winter. None of them have/had a vapor barrier. Only one has insulation under the concrete and the floor is heated. None of them had condensation issues on the concrete.
/ The last Barn. (maybe) #178
I have to be honest, your diesel tanks don’t look right. The paint is to shiny and they aren’t all rusty, at least that’s how they all look around here.
I'll have to post again in 20 years, they might look like all the others around me too.
I did get 2 quarts of paint with the tanks. I might give them a good second coat next summer.
I'm with you Richard, I've never used a vapor barrier under concrete and have never had a problem either. Even under a hay stack.
DT200 Diesel Tank (A64194)
DT200 Diesel Tank...
MOWER MAX SLOPE MOWER (A63276)
MOWER MAX SLOPE...
Ford 3930 Tractor (A65579)
Ford 3930 Tractor...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2022 EZ-GO ELITE...
