anyone using a WoodMaxx blower??
/ anyone using a WoodMaxx blower?? #181
I have a mahindra 1533 shuttle and am looking at a sb-72. My question is this. The specs on my tractor says the pto hp is 25. The specs on the sb-72 say at least 25 hp. Is anyone else running a sb-72 with about 25 hp? I checked with woodmaxx themselves and the said it would work but you would need to go slow and it would not throw snow as far as a unit paired to more hp at the pto. Just wondering how it would be at the minimum.
I'm running that blower on a Kioti with 45 PTO hp. In heavy snow you will have to go VERY slow, like under 1mph. That may be OK depending on your purposes, but it may be difficult with a shuttle-gear tractor (which I also have). Is a 60" blower an option? Do you have a creeper gear allowing full engine RPM at sub-1mph speed?
/ anyone using a WoodMaxx blower?? #182
I have a 60" Woodmax running on a Kubota B2150 hydro (18 hp pto) and it works well. Aside from horsepower, another consideration is the weight of the blower. It's a very solid unit and the weight of the 60" is 700 lbs. I don't have a FEL and needed to add substantial weight to the front of the tractor to get traction on the front wheels.
/ anyone using a WoodMaxx blower?? #183
1st low is pretty slow. I was looking at a 72” because my tractor is approximately 63” wide and the road I am planning on building will have a couple of turns. Plus it seems to me that having a few inches clearance on the wheels would make my current small parking lot easier to blow.
/ anyone using a WoodMaxx blower?? #184
Not a WoodMax, just a farm King type, open gears. Massey 1742 cab, 84 inch blower with a 20 inch fan. Hst works great. Lots of watching the mirrors, straight half mile drive.
/ anyone using a WoodMaxx blower?? #185
That all makes sense, but I'll tell you 1st-low on my Kioti isn't slow enough with my 45 pto hp when there's 14"+ of snow to clear. HST or a creeper gear would fix this issue, but I have neither. I expect you would be fine for 4-5" snowfalls but the reputation of upstate NY suggests to me you get more than that sometimes. We sure do.
/ anyone using a WoodMaxx blower?? #186
Hi everyone-
Hope thread is still open. I've noticed 2 things about the Woodmaxx compared to the Allied farmking blowers (only blowers I've seen in stock locally) in the 60" size. The Woodmaxx is much heavier and had a closed gearbox in oil. In the Allied it's open geared until you get into the bigger sizes. I understand the difference physically but what would the practical difference be if anything? Also the Woodmaxx has alot more spec info online. The only 2 things I can compare are weight (Woodmaxx much heavier so I assume heavier built all around) and the Woodmaxx uses heavier gauge chain.
So price is basically a wash for me one seems to be heavier unit and one has benefits of being a local deal. For additional info I have a Kubota B2650 and will be getting for use in Nebraska. So unless things really change (saying this year will be bad) it isn't going to get used like the guys up north use theirs. Maybe get away with the lighter built into to get benefits of local dealer?
Thanks a lot!
Their really is nothing you need a dealer for unless you hammer the **** out of the blower and break something major. I HAD an Allied and blew a jackshaft bearing. Went to my local bearing distributer and $12 later i was rolling. My Woodmaxx is far superior to my old Allied. for one i have a 24" 4 blade fan which throws way further than the Allied which had a 3 blade. I think the new Allied's are 4 blade now. Also the Woodmaxx has a serrated auger that cuts through hard pack. The allied would have to be rammed into hardpack. Again not sure how the new Allied's are but i wouldn't let the lack of a dealer hold you back from a Woodmaxx as it's a far superior blower IMHO. **** my LS tractor dealer was 210 miles away when i was in Montana.........
/ anyone using a WoodMaxx blower?? #187
Looking at the Woodmaxx SB60 on a TYM 330 HST, 25+hp est PTO. Last year I had 5 feet plus drifts and and need to get the snow out of drive. I ran out of room along side the drive to move snow. will this work or do I need a bigger tractor?
/ anyone using a WoodMaxx blower?? #188
You should have NO problem running a 60" with that tractor. My LS 3037 was 30.2 PTO HP and i had no issues running a 72"
/ anyone using a WoodMaxx blower?? #189
I'm upgrading my old Kubota L260 for a Kioti CK3510 this week. I talked to woodmax a couple days ago and planned on ordering a 72in snowblower and found out they offer a 5% Veterans Day discount. Now I'm waiting till Veterans Day and will help pay for the hydraulic rotate. 😁
/ anyone using a WoodMaxx blower?? #190
I'm thinking about an SB60 for my Yanmar EX3200. My tractor is rated at 25 HP PTO, so it's right in the middle of the recommended range for this blower. My tractor wheelbase is about 1-2 inches wider than the blower, but I don't think I can run an SB72 on this tractor. I would probably set up the tractor for winter with my 72" snow blade on front, which weighs about 420#.
I have about 1000' of driveway that I clear, most of which is gravel. There is about 70 feet of 2-car wide concrete driveway leading up to the house, and another concrete pad in front of my shop. The terrain isn't completely flat, but I only have one short hill that is at all steep - easy to handle by clearing it in two passes downhill.
Thoughts about this setup?
I do have a WoodMaxx chipper, so I know what to expect in terms of the quality of their products and customer support - both generally excellent.
Dave
/ anyone using a WoodMaxx blower?? #191
/ anyone using a WoodMaxx blower?? #192
Dave
Your setup with the plow for smaller storms and the 60" unit should serve you well to clear and blow the deeper snow then any clean up you can do with the blade.
Most of the time we get snow in the 4-10" range here, so a blade cleanup is faster, but when the sides close in with the plowed piles is where the SB is needed for the larger storms.
/ anyone using a WoodMaxx blower?? #193
I bought a SB60 WoodMaxx blower for my Kubota B2150 (18 HP PTO) last year and it worked really well. My driveway sounds similar to yours ~ 1000' gravel with a short, steep hill. The blower is heavy and I don't have a FEL so I had to add around 350# to the front end. I was able to do the driveway in 2 passes, down and back up, although if we get a really deep snow I'll probably resort to 2 downhill passes. My tractor has turf tires so I added chains for the hill. I'm impressed with the quality of the unit.
/ anyone using a WoodMaxx blower?? #194
I have an SB60 driven by Kubota B2650. I have fooled with the top link pitch as well as adjusting the skid plates but still can’t seem to get the blower level. The blower should be level, right? Seems to tilt downward (front is higher than the cutting edge side). It works fine but it just bugs me.
/ anyone using a WoodMaxx blower?? #195
Is there more than one attachment point available on the tractor side of your 3 point arms? Can you post a picture of the lower arms where they're pinned to the bottom points on your blower? I seem to recall another poster with same issues, and he was in the wrong pin holes on the blower side.
/ anyone using a WoodMaxx blower?? #196
Hello Hillstreet,
Are your lower links fully extended???
Is there a slot in the top link or just the pin hole?? Check the steel on the snow blower top link to see if t he hole is still circular.
About the lower links, the thing is the lower links can and will affect how the geometry of the snow blower looks and works.
I would extend the lower links and then level the snow blower again.
/ anyone using a WoodMaxx blower?? #197
ED0D2C20-1BD7-4475-821A-0502A621CF98.jpeg0A0958A9-7BDD-4F77-AFC3-A489F9C477D3.jpeg0A0958A9-7BDD-4F77-AFC3-A489F9C477D3.jpeg5CD9BE28-53DB-4447-AF77-9EB59AD2D6AB.jpeg
Slim, here are a couple pics. The scrape blade is contacting the level concrete floor. The skid plates are too low and I will raise them. The side arms are in the upper position of the blower.
/ anyone using a WoodMaxx blower?? #198
/ anyone using a WoodMaxx blower?? #199
On the blower side, not sure if the top pin hole on the lower link pins is where you want to be. I'm thinking at least lower your lower link arms as far as they can go, and maybe go to the bottom hole where you pin to the blower, and try that.
/ anyone using a WoodMaxx blower?? #200
I may have to try that because what I just did does not work. I shortened the top link to make the blower level (inline with the tractor). The scraper blade is one inch off the floor and the feet don’t even touch the floor. In other words, the 3PH is positioned in its lowest dimension and the blower is still in the air. I even checked the drive line (disconnected it from the blower) and removed pins from the check chains. It will not touch the floor.
1980 Yamaha Sun Classic Golf Cart (A66408)
1980 Yamaha Sun...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
2017 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2017 GMC Sierra...
2018 P.J. Trailer Trailer, VIN # 4P5F82023J1283348 (A65563)
2018 P.J. Trailer...
