Snow plowing on soft ground
/ Snow plowing on soft ground #41
The gravel drive solution is simple. Replace your cutting edge with a heavy piece of angle. I did it on my new 90" Meyer Minute Mount with a 4x4x 3/8". You can grade anything smooth in the Fall and Spring. I also have an old 9' Meyer dirt drive plow from the 30's that works great on my "Monster M37".
View attachment 585270View attachment 585271View attachment 585272View attachment 585273
Have you tried it on a gravel driveway? Also does it leave much snow packed down?
/ Snow plowing on soft ground #43
I like using my 6' landscape rake with gage wheels. It seams to clear best with the least damage to the driveway least rock redistribution. The driveway is about 500' of 3/4" crushed rock. Once the backhoe is off the tractor, rake on and set, I can make 3 passes and be going back inside for a fresh cup of coffee.
Chris
/ Snow plowing on soft ground #44
We get the same wet snow rain and thawing conditions early and late season. My plow does the same digs the gravel up. I ride back and forth with the truck plow UP just packing down a few tire tracks for the plow to ride on. That stops most of the gouging into the gravel. I hate raking up gravel in the spring.
/ Snow plowing on soft ground #45
Rear blade with adjustable bush hog gauge wheels. Set the 3pt in float.
/ Snow plowing on soft ground #46
I always thought this setup would be the best for removing snow on soft ground. Pull the pin and let it float side to side as well as float up/down on the 3pt, with the gauge wheels keeping the blade out of the gravel. IMG_1446.JPG IMG_1447.JPG
/ Snow plowing on soft ground #47
While it is not some sort of commercial grade plow, I have had excellent results with my SnowSport HD snow plow. Very cost effective and has done a great job. Simplicity can sometimes be a good thing. I never worry about taking out the gravel on 900' drive and I can push right on up into the yard around the out buildings and never worry about scalping the grass. To look at it, it may seem "cheesy", but it works very well. I had a local welding shop build me a winch frame for it and use a $60 winch I got off of Amazon to lift and lower the blade. All that is required on my pickup is a Curt 2" front receiver hitch.
SnowSport HD Utility Plow | Truck Plows & Snow Blade
This vid shows it working
SNOWSPORT(R) Utility Plows - YouTube
This vid shows how it contours to the landscape
SNOWSPORT(R) HD Utility Plow Testing - YouTube
Here it is on my 2015 Chevy 2500.....
/ Snow plowing on soft ground #48
Nice job, I had wheels on a snowblower once but they still picked up some stones, not as many. I just rake in the spring.
/ Snow plowing on soft ground #49
THANK YOU...:)
I had a piece of 3" angle laying around so I tried this.
Drilled a couple holes in it & a thin strip of bar stock & bolted it all to my York rake.
Doesn't cover the entire width of the rake but seems to work GREAT at not digging up the grass drive down to the barn.
Didn't clear the gravel drive as much as the regular plow on the pick up but also didn't seem to disturb the gravel.
Thank you again.
/ Snow plowing on soft ground #51
My stone drive is also a walkway so it cant be packed snow that will turn to ice or the wife will fall. I try for quick and easy solutions first. Floating the FEL and back-blading seems to work pretty well for me. I adjust the bucket edge angle so that it pulls the snow but not the stones. The more vertical the edge - the more likely to move stones. I go as vertical as possible without grabbing the stones. My drive is only only 200 ft. so driving backwards is not too much trouble.
/ Snow plowing on soft ground #52
My plow has skid shoes like the edge tamer only even wider and they still dig in when the ground is soft. The pipe worked reasonably well for me.
Ken
/ Snow plowing on soft ground #53
I have DIY edge tamers on my plow and snow blower.
Np spring raking for me.
So far this winter I have not had to replace a shear bolt on the blower either.
This year lots of snow came B4 freeze up and 'tamers' were a blessing.
/ Snow plowing on soft ground #54
Pictures? (especially of your snow blower set-up.)
/ Snow plowing on soft ground #55
I typically use the back side of the rear blade to avoid pushing gravel and have the Edge Tamers on the bucket on the front. It really depends on what type of snow it is. Usually the rear blade does OK but this last storm we got was about a foot of snow then freezing rain on top so the blade just rode up on top of it, so I had to use the bucket to break it up, then clear it nice with the rear blade.
One thing that I noticed that definitely helped was switching from 2b limestone to 2a for my driveway. It's something that folks may not think about but your driveway material does make a difference. 2a is smaller and packs much nicer to begin with, which is great for driveways like mine that have a steep hill. People would get stuck in my drive in the middle of summer with 2b, lol. So having it packed better and flatter means less digging in when plowing snow. The Edge Tamers work much better with the 2a too whereas they would just push through the 2b and the bucket would still dig in. 2b stays prettty loose and the blade pushes it around pretty easily too, but it pretty much glides over the 2a. So at my place, 2a makes a world of difference all year round.
With the majority of my drive being a hill, I can't afford to pack it down first or leave a few inches on the surface. It needs cleared pretty well or it becomes miserable for anybody without 4wd, good tires, and some skill. Especially like now when it is basically solid ice, sometimes it comes down to spreading rock salt to have a manageable surface without destroying it and having piles of gravel to deal with come spring.
/ Snow plowing on soft ground #56
Talking about freezing rain,\
Whenever I suspect it's to be I leave the snow there.
The snow acts like a sponge and most often a crust forms on top thus shedding the rain.
I wait 'till colder and plow or blow as needed.
In that manner I have a dry drive with a 'tractionable base'. Works for me.
LOL, I hate sanding.
/ Snow plowing on soft ground #57
I am trying to learn crushed stone sizes but it seems that every site I find has different ratings. Can you explain the difference between 2A and 2B. I thought that the number was the size of the largest stone. I don't know what the A or B means. I assume that both of these are "modified" (not washed - containing fines & dust) so that they pack well.
/ Snow plowing on soft ground #58
I also find that confusing.
I prefer the method used in my area which calls it as it is.
Example: 0-3/4 is just that, dust up to 3/4" (might be known as crusher run in some areas) and 3/4" clean gets you washed 3/4 stone.
That 0-3/4 makes a nice driveway finish as it packs well but ruts in heavy rains on hills.
Experience has proven recycled crushed asphalt is the best on hills and has the advantage of being cheaper to purchase.
Hauling costs just about as much as the materials.
/ Snow plowing on soft ground #59
I'd be interested in seeing pictures of the set up on your blower, thanks.
/ Snow plowing on soft ground #60
Heres some pics of my solution, and it works perfectly. (6 foot front mounted blower)
I had the local steel supplier take a piece of 5/16 by 6 flat stock which was 74” long.
I had him put a 30* bend 1 1/2” from the front edge. It looks like a ski, 6” front to back, but 74” wide.
This was attached under the regular wear strip under the blower. I used (4) 7/16 plow bolts. I drilled these extra holes so the skid was demountable without having to remove the original wear strip bolts.
I had a hard time countersinking these holes for the plow bolts, but got it done.
The steel and the bend was around $40, and I had several hours in drilling, countersinking and mounting.
I had a tough time countersinking those bolts, but it really works. I can go on rain soaked, unfrozen grass during the first few snowfalls, and it doesnt EVER dig in. It also does not ride up except on the hardest of blown in drifts. In which case, I use down pressure and if I need to adjust course, I just have to stop, lift, correct the course, lower and down pressure, then proceed again. But I only had to use that procedure once in 2 years
I had planned to remove it after I built up a base of frozen snow, but it penetrates well enough that i havnt removed it in 2 years.
2015 JOHN DEERE 644KH HYBRID LOADER (A66091)
2015 JOHN DEERE...
Spartan SRT-XD Zero Turn Mower (A66285)
Spartan SRT-XD...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
CF Grapple (A64127)
CF Grapple (A64127)
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
