Yanmar YM2000 Fuel Pressure/ hard starting
/ Yanmar YM2000 Fuel Pressure/ hard starting
Ouch! You did the right thing, pulling the pistons.
I wonder if it was cranked with water in the cylinders to bust up stuff like that.
My guess is, at some point in time it was. If you look back on page 11 you will see the pictures I posted last night.
ouch ! Does that engine have cylinder liners ?
It appears to, I will try honing first, if it’s not enough then it will have to come all the way out and apart and go get re-sleeved. I was really hoping to be able to do an “in frame” rebuild, but we will see.
/ Yanmar YM2000 Fuel Pressure/ hard starting #123
If you can get them out. You should be able to install new sleeves
What’s the best method to getting them out? I’ve done several gas engines and my old Cummins, but none have had sleeves.
/ Yanmar YM2000 Fuel Pressure/ hard starting #125
never taken any out myself, but I have read in the past where someone has removed them.
If I'm not mistaken, there is a tool that is used to remove them.
Perhaps hoye has such a tool
/ Yanmar YM2000 Fuel Pressure/ hard starting #126
Yes YM2000 has sleeves/liners.
Hoye diagram.
Note in the diagram, the crankshaft slides out the back of the block so replacing main bearings isn't trivial.
A buddy of mine is a certified diesel tech up at the semi dealership here in town. I’ll be borrowing his hone anyway, I’m sure he can help remove the sleeves if we decide they need to be replaced.
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
2022 John Deere 5055E (A60462)
2022 John Deere...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2002 WACKER RD25 ROLLER (A59906)
2002 WACKER RD25...
2019 John Deere R-4038 (A61306)
2019 John Deere...
