bmaverick
Super Member
- Joined
- Sep 17, 2013
- Messages
- 7,436
- Location
- Beloit-WI
- Tractor
- Yanmar YM2610 ■YANMAR GURU■ EXTRAORDINAIRE
I thought the procedure was like this,
Here is the process it describes for my tractor.
1) Shut off fuel and disconnect #1 injector line from pump
2) Unscrew delivery valve holder from pump and remove spring and delivery valve
3) Reinstall holder and copper washer
4) Attach a fabricated line onto pump #1 injector outlet
5) Place a ratchet and socket onto crankshaft nut
6) Rotate ratchet clockwise until #1 cylinder approaches TDC on compression stroke
7) Place small container under fabricated hose and turn on fuel
Comments
Since delivery valve was removed a steady stream of fuel will come out until crankshaft reaches a certain
point. At which fuel will slow and eventually stop. Disregard the last drop or 2.
The point at which fuel stops flowing is called the beginning of the injection cycle.
Once fuel stops completely check injector timing mark.
(its the one about 24 degrees BTDC which has a #1 stamped on it)
It should be aligned with the pointer.
If mark has gone past pointer remove shims, if it has not reached pointer add shims. 0.1mm shim is
about 1 degree
Comments
about 1 degree
