John0829
Veteran Member
Something that works good and is less damaging is a gasoline soaked rag over the intake... be sure to hold on tight.
Grid-heaters/intake manifold heaters do not like starting fluids of any type. They tend to explode destructively. Glow plugs are OK if the starting fluid is used prudently.I was taught that only applies to diesels with glow plugs or pre-heat systems doesn't it??
used sparingly has been a staple for century hasn't it?
its still sold today for use on diesels by many manufacturers like Lucas etc..... approved for use on diesels.
happy to be proven wrong though.
Cheers
AG diesel fuel is the same price as on-road diesel, the difference is no sales tax collected on red AG diesel, you pay sales tax at state tax filing time. AG diesel is pumped into the delivery tanker from same storage tank as on-road diesel. That is also where the different percentages of biofuel is added.Yeah, I’m kinda thinking that gravity feed systems where the tank has the fuel line in the lowest possible spot are going to remain fairly sludge free, unless you buy diesel that was nasty to begin with. Ag diesel may be a lot cheaper, but it also has a much lower quality control because it’s rarely inspected. Know and trust your supplier, or get a different supplier.
Also no highway taxes. So at least here it's the amount of the taxes lower. Still to high though.AG diesel fuel is the same price as on-road diesel, the difference is no sales tax collected on red AG diesel, you pay sales tax at state tax filing time. AG diesel is pumped into the delivery tanker from same storage tank as on-road diesel. That is also where the different percentages of biofuel is added.
Good catch; that's also what I was thinking of but got it wrong.Also no highway taxes. So at least here it's the amount of the taxes lower. Still to high though.
This cracked me up. Is your alpaca wool white or black alpaca? Were they over-the-road alpaca, or off-road, or blended? So many questions!I've decided to run straight fry-o-lator oil that I collect from the local hardlees burger shop. I'm going to filter it through freshly shearn alpaca wool. I will use hyper-milage techniques whenever possible. ;-)
Now can we start a conversation on which brand oil (or filter) is best?
I thought he was that red headed British singer. Ed Shearn.And is "shearn" really a word?![]()
Thinking of the cold weather, does #1 diesel have a higher cetane than #2? It won't gel on you, but I don't know about starting.Grid-heaters/intake manifold heaters do not like starting fluids of any type. They tend to explode destructively. Glow plugs are OK if the starting fluid is used prudently.
#1 diesel fuel is a mixture of #2 and kerosene, I don't know the ratio, but dad always mixed it 1G kerosene into 10G #2 during cold weather. Can't do that in warm/hot weather as it gets the engine too hot. The kerosene increases cetane rating to 48 or higher, depending on mixture.Thinking of the cold weather, does #1 diesel have a higher cetane than #2? It won't gel on you, but I don't know about starting.
#1 diesel is made specifically as #1 diesel. It’s almost identical to kerosene, but kerosene must pass a couple different specifications.#1 diesel fuel is a mixture of #2 and kerosene
FWIW:Using the wrong type of fuel. ...
I am the OP... are you trying to say I said this?Would a real person (well, one that thinks) suggest that one of the worst things you can do is running red diesel instead of taxed, or vice versa?
