9 Worst Things You Can Do to a Diesel Engine
   / 9 Worst Things You Can Do to a Diesel Engine #61
"In diesel engines, where internal pressures and operating temperatures are often higher than in gas engines.."
That statement is wrong. Diesel burns much colder than gas and is less violent than gas, that's why diesel engines last much longer as diesel does much less wear and tear on the engine parts compared to gas
   / 9 Worst Things You Can Do to a Diesel Engine #62
My first diesel pickup was the 6.2 - an engine that doesn't have a great reputation - the truck rotted away around it but the engine never failed me. 3,000 mile oil changes (100 hour tractor) is cheap insurance to a reliable and long lasting engine.
Heating oil BTW is the same as diesel - untaxed and illegal for road use but is also ultra low sulfur - at least in the state I reside in.
I had a 6.2 in a K5 Chevy Blazer and had more trouble with the starter than anything I think I replaced it four times
   / 9 Worst Things You Can Do to a Diesel Engine #64
The OP is obviously an AI generated list. AI compositions used to stick out like a sore thumb. Not any more. Sometimes you have to look closely to detect them. Answers that just don't quite seem right, or don't seem to apply to the question at hand. I live in SW Missouri. I guess we are lucky down here in farm country. We have 2 grades of diesel, dyed and clear. That's it. Where we all buy our diesel around here the pump says nothing about any of these parameters. There's one hose to use. The pump just says "Diesel". I'll have to look to see if it even says #1 or #2. But honestly, here in farming country, we all just buy whatever the supplier delivers and don't worry about all this stuff. It wouldn't do any good anyway, as we don't have any other choices in diesel. I've got other things to worry about, like paying my income and property taxes, insurance on my place, utility bills, where to eat lunch, etc. What diesel I burn is pretty much at the bottom of my non-AI-generated list.
   / 9 Worst Things You Can Do to a Diesel Engine #65
Don't agree with some points made in this discussion.
1. All diesel fuels are not the same. We had a customer whose combine always had a light colored smoke, he was doing some custom work and filled the tank with the farmers fuel and the smoke went away, when he filled with his own fuel the smoke returned.
2.If starting fluid is so bad why did manufacturers install devices to inject it? As someone that worked at a farm equipment dealers we used either to start many diesel engines, without any damage.Never did find it to work on gasoline engines.
After the glow plug system died on my 6.2 diesel used to give it a sniff to start when cold. The body died before the engine, in fact sold the engine for a fellow to put in his truck, and it had over 300, miles on it.
3. Is it better to leave a diesel sit and warm up or leave it run just long enough to get the oil circulating and a little heat in the combustion chambers, and then move out under a light load until it is up to temperature?
   / 9 Worst Things You Can Do to a Diesel Engine #66
Unless it's very cold (like today) I let mine run at about 1000rpm for a minute, then take off. If it's below 35 or 40 degrees I'll let it run at fast idle another 3 or 4 minutes if I have time to wait. But, I don't work my tractors hard anymore since I retired. I wouldn't drop a plow until the engine is warm, but scooping up a load of dirt and hauling it a few yards doesn't bother me at all. My Kubota M9000 is 22 years old, bought new in 2003, and I have never once had any issues with the engine whatsoever. Of course everyone's mileage may vary.
   / 9 Worst Things You Can Do to a Diesel Engine #67
Idling an engine at cold start is not best practice. Much better to lightly load the engine right from the get-go to promote rapid warm-up. This applies to gas engines as well. As soon as I start, I move - lightly but moving for sure.
   / 9 Worst Things You Can Do to a Diesel Engine #68
Best loaded operating range is between the torque and hp peaks (latter is "usually" full throttle). Always makes me laugh when some say two-stroke Detroits "must be kept screaming". It's just not true. Example - common 8V71 NA build - torque peak is 1400rpm and high idle is 2100. That's how I run all my diesels under load. When not under load (e.g. driving the pickup around empty), then I let the truck decide itself.
   / 9 Worst Things You Can Do to a Diesel Engine #69
I run red dye in my 02 f250 7.3 with 44K all the time, they never check on a pick up truck and it run just the same with road fuel.
   / 9 Worst Things You Can Do to a Diesel Engine #70
I was taught that only applies to diesels with glow plugs or pre-heat systems doesn't it??
used sparingly has been a staple for century hasn't it?
its still sold today for use on diesels by many manufacturers like Lucas etc..... approved for use on diesels.
happy to be proven wrong though.
Cheers
When used correctly (only add when engine is turning, and in small amounts) it is fine. Ol' Super Blue (Ford 9600) came with the system.
2001 Ford Explorer SUV (A56859)
2001 Ford Explorer...
1994 Club Car Electric Cart (A56859)
1994 Club Car...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58375)
KNOW BEFORE YOU...
2015 Dodge Charger Passenger Car, VIN # 2C3CDXAT4FH817483 (A57453)
2015 Dodge Charger...
