Yanmar ym2000 no start
/ Yanmar ym2000 no start #31
Like I said you have no compression... possibly holes in pistons from ether. Really do a compression test to make sure but I don't believe you have enough compression to run and start. If your seeing white smoke your getting fuel how much I have no idea, enough to run, again I have no idea but I would think it would at least sound like it was trying to start if you can see smoke.
/ Yanmar ym2000 no start #32
For a last trial before tearing it down, I would add a second, jumper battery to crank it more vigorously. Or try tow-starting it.
It would be easier to analyze if its running.
/ Yanmar ym2000 no start #33
I'm late to the game here.
Did the OP also check to ensure the decompression system is not broken with a compression leak? Late last year a person on another forum we were helping with finished rebuilding their engine. When they got it all installed and the machine put back together, the decompression cable was set backwards. So, the engine would crank and crank with no starting.
Just a thought.
/ Yanmar ym2000 no start #34
I rewired the fuse box and bled the lines and it was a dirty fuel filter. Check your fuel filter. Mine started right up without it.
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
2023 Chevrolet Express Van, VIN # 1GCWGBFP8P1104620 (A61165)
2023 Chevrolet...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A61307)
2022 Greenworks...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
(INOP) 1991 GMC TOPKICK DUMP TRUCK (A59823)
(INOP) 1991 GMC...
