Yanmar ym2000 no start
/ Yanmar ym2000 no start #1
James russell
Yanmar Ym2000
I just bought a Yanmar ym2000 and was told by the previous owner that it would take about 15 min to get it started and that it was getting air in the fuel. I bled the fuel system, hooked battery up to jumper cables and cranked on it for a while with no luck. Since then I tried multiple times to bleed air out at injectors and I’m not getting any air at all so I believe I have it all out. I figured maybe I had an injector issue so I pulled one out and tested it. It worked fine. I’m getting a good bit of white smoke out of the exhaust so I assume I’m getting fuel to the engine. The engine definitely has good compression and I am using the decompression lever to try and get it started. I’m getting fuel, air and compression and the engine doesn’t even seem like it wants to start. I even tried a bit of ether but it wasn’t doing anything so I didn’t keep using it. The engine is almost acting like It has a bad shut off solenoid but it doesn’t even have one. I’m really confused with this one so any help is appreciated.
/ Yanmar ym2000 no start #2
click here to see how Yanmar handles glow plug duty. Do not use ether again,it can blow a gasket,bust a piston or worse. But since you did and it didn't hit with ether, check out that link above. If thermostat is working I think it is money well spent having a pro look at it. Someone might have had the pump off and got it out of time or some other unusual thing.
/ Yanmar ym2000 no start #3
Blk. smoke would be oil rings or uncombusted fuel. White sounds like a Vapor issue. Head gasket, cracked head etc.. I would chk. the Radiator pressure for pressure build up and watch for the cylinder pressure to leak down. Then your know pretty much what condition the motor is in. Already had one InJ out so should be a easy thing to do. Rent the pressure test kit at most any Large chain auto store. On a YM2000 you should come in around 18 PSI if I recall. Check you Exhaust and muffler for water Esp if it sits outside and no cap on the exhaust pipe.
/ Yanmar ym2000 no start #5
Don't pretend to be an expert but have worked on several Chinese Jinma pumps. Most Chinese parts are copies of some older successful American or Japanese model. Having said that most work on a rod or other mechanism attached to throttle and governor that controls how far the pumping pistons are pushed each stroke. On the ones I have seen this rod though controlled is also free floating. In other words it doesn't have to return to minimum when controls are lessened. Therefore if it doesn't return on its own the tractor could basically run away until gas and air are starved. I encountered one once and it took about 20 minutes to get it under control. After you have tried all else look for a side plate or opening and spray brake cleaner into it. Do not try to clean or you risk scratching it or getting foreign matter inside.
Your control could be stuck and doesn't want to let fuel in or stuck at a point it won't close to optimum place and the sudden input of too much fuel negates your attempt to heat the cylinders.
I have also found that lines going to the pump from tank can cause the problem by leaking air into the system. Some are steel mesh coated but are not really under any pressure at that point.
Hope this gives you other avenues to check out.
Thanks for all the replies. My thermostat is working and was just replaced by the previous owner. I haven’t done any compression test so I don’t know for sure that it has perfect compression but when I was taking the injector out I turned the engine over to push it out and it just about shot out of the head so I assumed compression wasn’t an issue. But I will still do a real compression test to make sure it’s good. Also since I’ve had engines with very low compression I know that even with low compression an engine will still at least fire a small amount and I haven’t even gotten that out of the tractor. As for the smoke out of the exhaust I would say it’s a little on the grey side rather than white but I guess it still could be vapor. I check the radiator and I don’t see any oil in the coolant and it looks pretty clean. Could valves be an issue?
/ Yanmar ym2000 no start #8
Called a leak down on a compression test and no thermostat on a YM 2000 looking like it's not Low It's no compression. Hit it with the either. Sounds like no doubt a big problem.
/ Yanmar ym2000 no start #9
I skipped to the bottom but I would guess that it has no compression or engine damage taking that long to start. My guess is that previous owners and you as well have used either and it's now dependent on it to start do to weak compression or damage unfortunately.
/ Yanmar ym2000 no start #10
White smoke starting is unburned fuel. If your pour diesel into coals in a fire it will put out white smoke. The black smoke when one is under heavy load is raw unburned fuel basically being blown out of the exhaust.
/ Yanmar ym2000 no start #11
Just to clarify; Yanmars use a thermostart (with an R) to preheat the air intake. I think that is what @jaxs was referring to. (Autocorrect can be a pain sometimes...) The link that @jaxs posted will explain it in detail. Are you following the manual on how to start the engine? Yanmars have a specific routine.
White smoke is cold, unburnt diesel (bad injector, blown rings or head gasket), or a coolant leak into the cylinders. The fact it won't light off on any cylinder makes me suspect either it's cold (no thermostart in use), or something worse like a head gasket, as none of the cylinders are catching.
All the best,
Peter
/ Yanmar ym2000 no start #12
All the best,
Peter
I don't know if much of the lower 48 has been cold enough recently where a healthy diesel won't light off and catch without thermostart? Maybe if he was trying first thing in the morning on certain days in the upper portions of the country maybe?
/ Yanmar ym2000 no start #13
Never get any white smoke! Cold or hot use the Thermal or not. BLK. as can be from the first hit until it clears the unburnt fuel. I always use the Decompression. So when you do that and wait for the Oil light to go out your loading up the Cylinder with fuel. Or should be and get Blk smoke from it. Never gets white and no coolant problems. Temp. sender Yrs. ago about it. Average a count to 6-8 before the Oil pressure light goes out. I can honestly say I've never cold started it until the oil light goes out and pressure is up. Still runs the same as always. Org. and you seen and heard it!! ;)
/ Yanmar ym2000 no start #14
The OP doesn't list his location...
/ Yanmar ym2000 no start #15
I don't either but it is white. I'm around enough old ratty logging equipment and heavy equipment and trucks to see it.
/ Yanmar ym2000 no start #16
If u can gain access to the inj. pump while it’s still in the engine, do that and make sure the control rack is moving left and right..
I’m assuming it’s a “PFR” pump.?? Also know as a “cassette” pump..
I already attempted to pull the injection pump and it came about half way would and wouldn’t move anymore. I couldn’t find much info on how to remove them so I just went for it which I’m sure I was wrong to do. Anyway since I couldn’t get it all the way out to inspect it I just put it back in and cranked the tractor over and fuel was still coming out of the pump like normal so I figured it was fine.
/ Yanmar ym2000 no start #18
There is an injection fuel pump service manual for the YM machines located on the YTOG.
DO NOT disassembly the fuel pump just yet. It may seem simple, yet there are tricks to it inside with those plungers.
Before tearing into the fuel pump, it's best to consult with Mike @thepumpguysc
Mike the pump guy - Master Injection Pump Rebuilder
For Japan made tractors, namely many of the brands including Yanmar for fuel pumps and hydraulic pumps.
Mike can be reached on our message board from time-to-time, The best way is via email he typical monitors very often at:
thepumpguyscATaol.com
(Replace the AT with the @ symbol when emailing please)
- Mike has 35+ years in the industry with injection pumps and hydraulic systems.
- He is very well versed in the JIS and SAE standards for parts to ensure proper components are used for rebuilds.
- From Sunny South Carolina.
- When sending parts via mail, please be sure to have insurance for a bit more than what you can find it new due to carrier issues that 'could' happen.
There are many positive testimonies on many of the Industrial Equipment, Heavy Equipment, diesel boating, tractor and other forums on his work and professionalism.
Shout out to The Pump Guy | Heavy Equipment Forums
(2) Thepumpguysc rocks - TractorByNet
Timing fuel injection pump - Yesterday's Tractors (yesterdaystractors.com)
Ford 3600 leaking from where fuel inlet meets injector | My Tractor Forum
The Pump Guy - Yesterday's Tractors (yesterdaystractors.com)
/ Yanmar ym2000 no start #19
There should be a cut out in the engine block to allow the control rack pin on the pump to pass.. otherwise it’ll come up about an inch and stop..
The cut out is very close to shut off.. you can use the throttle to move the pump rack..
A lot of times, when the pump is forced, u end up bending the control rack and it sticks or is stuck..
THATS WHY I wanted you to gain access to the side of the pump.. TO SEE if the rack is moving with the engine throttle..
So I pulled the valve cover to make sure everything looked ok and make sure none were stuck. I cranked the engine over and white/gray smoke came out from under the head. I’m guessing I will at least need piston rings. But before I start tearing into it would it be worth checking valve clearance? I don’t know if it’s possible for valves out of adjustment to cause that issue.
