California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,638
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
That's good news! Where did you source the new pump?
You did all the right things except replace the fuel filter and bring. Bestfarmparts.com has the parts you need.Well I ran out of fuel in my 1510d. I filled the tank back up and bled the lines from the fuel filter and the port on the bottom of the IP (Phillips screw). Cracked all 3 injectors lines and cranked until fuel came out. Tractor lacks power and doesn’t sound like it should. For some reason I don’t think cylinder #3 is working or the injector isn’t working. While it’s running I can crack injector line 1 or 2 separately and the engine will die. I can take injector 3 line off all together and she still runs, fuel is coming out of the line but not very forcefully. And help would be appreciated.
You are correct. I should have changed the fuel filter after I ran out of fuel, hopefully I won't have to go through this again.You did all the right things except replace the fuel filter and bring. Bestfarmparts.com has the parts you need.
