1 cylinder not runnning Yanmar 1510d
   / 1 cylinder not runnning Yanmar 1510d
I ended up getting the pump from Tractor Parts To Go, I had already placed an order after I found out about Brand M parts which would have been $25 cheaper. Either way, I am glad its up and running.
   / 1 cylinder not runnning Yanmar 1510d #23
Well I ran out of fuel in my 1510d. I filled the tank back up and bled the lines from the fuel filter and the port on the bottom of the IP (Phillips screw). Cracked all 3 injectors lines and cranked until fuel came out. Tractor lacks power and doesn’t sound like it should. For some reason I don’t think cylinder #3 is working or the injector isn’t working. While it’s running I can crack injector line 1 or 2 separately and the engine will die. I can take injector 3 line off all together and she still runs, fuel is coming out of the line but not very forcefully. And help would be appreciated.
You did all the right things except replace the fuel filter and bring. Bestfarmparts.com has the parts you need.
You are correct. I should have changed the fuel filter after I ran out of fuel, hopefully I won't have to go through this again.
Unused 12x20 Carport With 10' Fully Enclosed Side Walls (A55272)
Unused 12x20...
Entyre Chip Spreader (A57453)
Entyre Chip...
Hydraulic rail grinder (A56436)
Hydraulic rail...
2015 KENWORTH T680 SLEEPER (A59575)
2015 KENWORTH T680...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57453)
New/Unused AGT...
