New to welding
/ New to welding
Trying to decide to buy a drop cord or run a line to run 220v. We bought some more land and plan to move and build on it in the next 2 yrs and I hate the idea of running the underground line and spending that money. Even though the convenience would be nice. Probably just run a drop cord to my small shelter and make a small work area there. Going to the shop where I keep all my tools just bothers me thinking about it though. Lol
/ New to welding
Thursday! How will you be able to sleep?
I know. Make it even worse I'll be out of town the following two weekends in a row. We compete in Field Trials with our bird dogs and this is our busy part of the season traveling & competing. So it'll sit on my shelf for a few weeks before I really get to spend some time with it.
/ New to welding #64
Your decision will come down to distance. How far from your 220 to where you want to weld? I am a big drop cord fan, and someone told me that RV Extension cords are quite affordable and can handle the amperage.
/ New to welding
110' from my meter pole to the shop, 50' to the small shed. Spending all the money to bury a cord and run power bothers me because I'll be leaving it behind, I can carry the drop cord with us when we move. Starting to lean that direction and just deal with the little inconvenience for the time until we get moved.
/ New to welding #66
Another option to evaluate is to get welding cable extensions. These can go with you when you move and are nice to have so you can work outside your shop area no matter what, if can't get the item into the shop due to size or weight.
I got mine years ago from a company called Cable Yard and got RADAFLEX® 1/0 AWG Black Welding Cable.
It has to be gauged sized for length and amps but it is another option to consider. Maybe a combination of options to use.
As long as it is sized properly there are no disadvantages (other than weight and I guess cost) to having stinger and ground lead extensions only advantages. (IMO)
Gauge sizing it is very important however.
/ New to welding
Furu, I really like that idea but our yard is fenced in & the meter pole is inside the yard. So I would have to walk around and into the gate to adjust settings, and being new I'll probably be adjusting alot to find the right amps. Haha
/ New to welding
Called a buddy up that owns a junk yard and told him I needed some decent scrap steel to practice welding. He loaded me up with about 200lbs of scrap steel. Best part I told him I needed a welding table and he just got some industrial stacking shelves from a warehouse. He's going to cut the legs off next week for me to the height I need and I'm just giving him scrap steel price for it. I think it was 4x8' and stout :). That was a good visit.
/ New to welding #69
BMan2005 here are the settings I use with my PowerArc 200ST. Now remember everyone welds a little differently, but these settings should get you close.
1/8-inch 6010
Flat, 70-AMPS
Vertical up hill, 65-AMPS
5/32-inch 6010
Flat, 100-AMPS
Vertical up hill, 90-AMPS.
3/32-inch 7018
Flat, 50 to 60-AMPS
Vertical up hill, 50 to 55-AMPS
1/8-inch 7018
Flat, 105-AMPS
Vertical up hill, 80-AMPS
5/32-inch 7018
Flat, 125-AMPS
Vertical up hill, 120-AMPS
/ New to welding #70
Oh, I forgot to mention:eek:. My 7018 comes right out of the rod oven, so the settings for 7018 maybe a little cold for you!
/ New to welding
1/8-inch 6010
Flat, 70-AMPS
5/32-inch 6010
Flat, 100-AMPS
3/32-inch 7018
Flat, 50 to 60-AMPS
1/8-inch 7018
Flat, 105-AMPS
5/32-inch 7018
Flat, 125-AMPS
I REALLY appreciate that shield arc! That'll at least get me close enough to get started. Will the 6011 be about the same as 6010? Also I bought 7014 instead of 7018 until I get me a cheap place to store the 7018's. Do you remember what you ran the 7014's at when you tested them?
/ New to welding
Also, what about the Hot start and Arc force settings?
/ New to welding #73
According to my note book, seems as I never ran 7014 with the PowerArc 200ST. Or at least I didn't write the settings down. Just guessing, I would say 7014 will run between 6010, and 7018 settings.
/ New to welding
With the PowerArc 200ST, those are automatic. You can't control them. The PowerArc 300, has adjustable settings.
Simple, even better. Thanks
/ New to welding #76
After seeing that amperage chart - it looks like the projects BMan2005 is likely to do, will all be under 100 amps. Would an inexpensive 12/3 50 ft extension cord with the proper ends serve to run power out to his shop at this light load? Assuming it is laid right on the ground temporarily for each welding project, even if it heats up some, it doesn't risk damage to structures etc like that gauge would if it were inside walls. Comments? Would the voltage drop be excessive?
/ New to welding #77
I never seen 7014 on the job site. Until seeing guys on these forums talk about 7014. I bought some, and later did a fillet weld break test with it. I was not impressed with it. 7018 that never seen the inside of a rod oven, broke with 18-blows from a 4-pound hammer. 7018 right out of the rod oven, broke with 23-blows from a 4-pound hammer.
Now to start learning to weld, 7014 is child's play to run!
/ New to welding
That's me. Haha
/ New to welding
1/8-inch 6010
Flat, 70-AMPS
5/32-inch 6010
Flat, 100-AMPS
3/32-inch 7018
Flat, 50 to 60-AMPS
1/8-inch 7018
Flat, 105-AMPS
5/32-inch 7018
Flat, 125-AMPS
California brought up a good point. With those #'s wouldn't I be just fine running 110v since I don't plan to step over 1/8" rod no time soon?
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63118)
2024 Kubota...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2024 Keystone RV Retreat Camper, VIN # 4YDTHRT28RW260127 (A61165)
2024 Keystone RV...
UNUSED WOLVERINE SB-12-72W 72" HYD SCREENING BKT (A62131)
UNUSED WOLVERINE...
