How much tamping required for a culvert?
/ How much tamping required for a culvert? #1
Fallon
Super Member
Parker, CO
Kubota L4060hstc, formerly L3200hst
Borrowed a friend's backhoe for a couple projects 2 weeks ago & dug a trench across the driveway just before it had to go home. Trench us to deep (kind of by design). I finally picked up the required 25' of culvert yesterday. 12" double wall corrugated outside smooth inside stuff.
How well do I have to worry about tamping under & around the culvert? It's going to be snowy & muddy for the next week or 2, so good tamping really won't be possible. And the trench is slowly starting to cave in, especially with the moisture. 3' trench, 1' of culvert & generally you need 1' over the culvert, so I need to backfill a foot or so.
Not to worried about settling causing a dip as I have a box blade & maintain the driveway regularly. Not to mention needing to dump more gravel on it this summer or fall.
I'm mostly worried about the culvert crushing before stuff settles or it getting really out of kilter.
Can I skimp on tamping because of the mud? Should I wait for it to dry out a bit in a few weeks & manually re-excivate the trench as needed & tamp by hand? We can drive around for now, but it's tearing up the grass a bit.
I do need to re-grade the exit side of the trench smoother & a bit deeper a but should be able to do that with the box blade after the culver is in & leveled just past plumb so water will flow.
/ How much tamping required for a culvert? #2
It being a gravel drive will be much more forgiving than if the surface was paved. Cheat the compaction if you'd like and just recognize that you'll have to fill in with some gravel a few years down the road.
Looks like your culvert is set a bit deep, unless you have plans to do a lot of digging at either end.
/ How much tamping required for a culvert? #3
I've installed hundreds of culverts. No tamping required. Lay the culvert against one side of the trench and fill with the smallest clods you can until you get above the culvert. Tamp with the backhoe tires. Then come back when things have settled down a bit and do some finish work. Leave excess material on sight so you have stuff to refill after settling.
Thanks. Ya, the trench is to deep, need to back fill a bit & clear out & taper the inlet & outlet a bit. Need to re-grade the driveway up the shop (hidden behind the hoe) too. It currently tilts away from the culvert a bit.
/ How much tamping required for a culvert? #5
There are articles that will explain how to properly install a culvert so it doesn't collapse or wash out.
/ How much tamping required for a culvert? #6
FWIW...
The capacity of any culvert to
carry loads depends on proper
backfilling, especially in the area
under the haunches (lower third).
The soil surrounding the culvert
provides critical support to it. For
maximum strength, and to pre-
vent wash outs and settling, the
backfill must be properly placed
and carefully compacted. Dry
trench conditions make the
process more efficient.
The National Corrugated Steel
Pipe Association culvert instal-
lation manual tells us too much
emphasis cannot be placed on
the necessity of adequate com-
paction of backfill. Faulty com-
paction has led to more trouble
with pipe installations, flexible
and rigid, than all other factors
combined! There is no way to
say it better.
There are two important
things to consider in backfilling:
use no more than 6 lifts at a
time and compact it evenly and
well, particularly under the
haunch of the pipe. Backfill
material should be free of rocks
larger than 3 in diameter. The
material must be dumped care-
fully and evenly along both sides
of the pipe. Avoid dumping large
quantities at once against or on
top of the pipe. The material should also have enough moisture to compact well, but
not too much so as to become unstable. This can be dif-
ficult to achieve, but produces excellent results. Watch
the weather closely during installation, particularly the
chance of heavy rain.
Hand tamping is adequate and is often the best
method to compact and seal the backfill against the
lower half of the pipe. If you use mechanical com-
paction, work parallel to the pipe, not against it. If large
equipment is used for compaction, don稚 over-compact
so that the pipe begins to lift or is pushed laterally out of
alignment. This is particularly important for flexible pipe
arches. Continue filling in even lifts until the installation
is finished. It is best to have at least 24 of fill over a
pipe, even on low-volume rural roads.
The most common problem with backfilling opera-
tions is that the filling crew works too fast and the
tamping crew never has a chance to adequately compact
the first material before more is placed in the trench.
To
prevent this, instruct filling crews to wait until a layer
is fully compacted before adding another layer.
/ How much tamping required for a culvert? #7
Good Show /Pine.:thumbsup::thumbsup::thumbsup:
Government road contracts are usually kinda fussy about culvert backfill methods and materials.
/ How much tamping required for a culvert? #8
Missouri DOT uses a hydraulic tamper. Then for the next 5 or 6 years they attempt to repair the area. Their mistake is digging the trench exactly the width of the culvert. No room for compaction so wasting their time. :(
/ How much tamping required for a culvert? #9
Soo, your saying improper compaction don't work?
/ How much tamping required for a culvert? #10
I'm saying improper installation doesn't work, regardless of how much you compact.
OP is going to fill the bottom of his trench to elevate the culvert, which is great. Gives the culvert a "loose" bed to lay on. Then start filling with small material, finishing with the larger clumps. Pack with backhoe front tires and let Mother Nature do the rest.
I have never, ever installed a culvert that didn't settle, compacted or not. So just expect to do maintenance on it for a couple years depending on soil type.
/ How much tamping required for a culvert? #11
I just put in 3 culverts last fall. I dug correct depth to allow for a 2-3" bed. I laid in the culvert and my son and I tamped it with small lifts setting the bottom. We continued to add, tamp, add, tamp using crusher run and dirt. After the top was covered and about 4" covered and packed, I filled the rest , packing with the tractor wheel. I mounded about 6" over the top and have been driving over it all winter. You can see how it has slowly settled, but very minimally. Looking inside shows no crushing.
You can tell, however, which culvert we did first and last. The first has a tall hump remaining in place and the last has about 1/2 the size. Although both humps were approximately the same height when finished. I suspect it is because we tired as we went and compacted less well on the 3rd.
/ How much tamping required for a culvert? #12
When you raise the trench bottom to the right grade, compact it well. The last thing you want is a a low spot in the pipe from settling where water and silt will collect and eventually give you trouble.
/ How much tamping required for a culvert? #13
Usually the grades staked will have excess camber to allow for settlement of the base as fill is added.
/ How much tamping required for a culvert? #14
So with the culvert against one side of the trench how do you backfill on the bottom side of the culvert?
That's why the staked bed has excess camber in it. And the bed will also be checked for grades and compaction.The deeper the fill the greater the camber.
How do you do maintenance on an installed culvert. Cleaning is about all that can be done.
Using backhoe tire's for compaction will not get you the proper compaction. They can't get near the bottom area of the culvert that needs support or it changes shape as fill is added. There are times tests are done for this or even ongoing inspection as the work is being done.
It's a private culvert installation but it should still follow the basic installation procedures to be successful.
/ How much tamping required for a culvert? #15
Around here we have about 4 ft of frost.
The new norm is to compact flush and then add 2" of foam board on top which makes for earlier thaw and flow come spring thaw.
Seems to work quite well and saves them from steaming the culverts open come spring thaws.
/ How much tamping required for a culvert? #16
Hydraulic Compaction. Compact best you can to half way up, dump 6" of 5/8 minus w/lot of crusher fines, wash all the small stuff into the voids in the larger rock with a water hose or pump if ditch has water. Continue in 6" lifts till topped out. Settlement, if any, will be minimum. Head walls on the ends help to keep aggregate from sloughing out the ends.
Ron
/ How much tamping required for a culvert? #17
Backfill with fill sand, making sure you cover it at least a foot, or more to keep it from floating, then heavily flood it with water from the top. You can put coarse gravel at the ends to contain the sand, and let the water out. It will take more volume than a regular water hose. You will get close to 90% compaction, if flooded properly, washing the sand down along the sides of the pipe.
That is how engineers spec'd to back fill on smaller culverts, and the way we did it @ ODOT.
On large pipes prone to flooding, we backfilled with a low strength concrete grout. But the pipe most definitely will need anchored down. Two methods used were driving T-posts every few feet in an X fashion above the pipe, then wired together, or temporary dams at the ends on a live stream, and let it fill with water. Otherwise, they are like a submarine with no ballast, and will float.
/ How much tamping required for a culvert? #18
I installed my first culvert in 1989. I've never had a failure or washout. In fact I've replaced some galvanized culverts that I installed years ago that have rusted out. I now use dual wall plastic on all but those over 4ft diameter. I've installed culverts in all sizes from 12" to 96" in lengths from 20ft to 120ft. I've never used a tamper or hand tamped. If doing a large culvert I dig the trench double the width of the culvert and place it in the middle. On a small culvert like the OP is installing there's no concern about that. Use whatever method makes you feel good. :)
I'll see if it's decent enough to work on after work. Back fill the little bit I need & tamp that a bit. Thinking I'll use some of the pile of pea gravel I have left to bed it in a little bit. That will pack in without being tamped. Either dump some dirty sand on that to lock it in or just use the pile of dirt & drive over with the tractor to tamp the top.
It's not going to get a lot of flow, especially until I re-grade my other section of driveway (it will just continue eroding the wrong side of that driveway branch & dumping sediment in my main driveway about where the other end of the backhoe you couldn't see in the photos was parked.
