How much tamping required for a culvert?
   / How much tamping required for a culvert? #11
I just put in 3 culverts last fall. I dug correct depth to allow for a 2-3" bed. I laid in the culvert and my son and I tamped it with small lifts setting the bottom. We continued to add, tamp, add, tamp using crusher run and dirt. After the top was covered and about 4" covered and packed, I filled the rest , packing with the tractor wheel. I mounded about 6" over the top and have been driving over it all winter. You can see how it has slowly settled, but very minimally. Looking inside shows no crushing.
You can tell, however, which culvert we did first and last. The first has a tall hump remaining in place and the last has about 1/2 the size. Although both humps were approximately the same height when finished. I suspect it is because we tired as we went and compacted less well on the 3rd.
   / How much tamping required for a culvert? #12
When you raise the trench bottom to the right grade, compact it well. The last thing you want is a a low spot in the pipe from settling where water and silt will collect and eventually give you trouble.
   / How much tamping required for a culvert? #13
Usually the grades staked will have excess camber to allow for settlement of the base as fill is added.
   / How much tamping required for a culvert? #14
I'm saying improper installation doesn't work, regardless of how much you compact.
OP is going to fill the bottom of his trench to elevate the culvert, which is great. Gives the culvert a "loose" bed to lay on. Then start filling with small material, finishing with the larger clumps. Pack with backhoe front tires and let Mother Nature do the rest.
I have never, ever installed a culvert that didn't settle, compacted or not. So just expect to do maintenance on it for a couple years depending on soil type.
So with the culvert against one side of the trench how do you backfill on the bottom side of the culvert?
That's why the staked bed has excess camber in it. And the bed will also be checked for grades and compaction.The deeper the fill the greater the camber.
How do you do maintenance on an installed culvert. Cleaning is about all that can be done.
Using backhoe tire's for compaction will not get you the proper compaction. They can't get near the bottom area of the culvert that needs support or it changes shape as fill is added. There are times tests are done for this or even ongoing inspection as the work is being done.
It's a private culvert installation but it should still follow the basic installation procedures to be successful.
   / How much tamping required for a culvert? #15
Around here we have about 4 ft of frost.
The new norm is to compact flush and then add 2" of foam board on top which makes for earlier thaw and flow come spring thaw.
Seems to work quite well and saves them from steaming the culverts open come spring thaws.
   / How much tamping required for a culvert? #16
Hydraulic Compaction. Compact best you can to half way up, dump 6" of 5/8 minus w/lot of crusher fines, wash all the small stuff into the voids in the larger rock with a water hose or pump if ditch has water. Continue in 6" lifts till topped out. Settlement, if any, will be minimum. Head walls on the ends help to keep aggregate from sloughing out the ends.
Ron
   / How much tamping required for a culvert? #17
Backfill with fill sand, making sure you cover it at least a foot, or more to keep it from floating, then heavily flood it with water from the top. You can put coarse gravel at the ends to contain the sand, and let the water out. It will take more volume than a regular water hose. You will get close to 90% compaction, if flooded properly, washing the sand down along the sides of the pipe.
That is how engineers spec'd to back fill on smaller culverts, and the way we did it @ ODOT.
On large pipes prone to flooding, we backfilled with a low strength concrete grout. But the pipe most definitely will need anchored down. Two methods used were driving T-posts every few feet in an X fashion above the pipe, then wired together, or temporary dams at the ends on a live stream, and let it fill with water. Otherwise, they are like a submarine with no ballast, and will float.
   / How much tamping required for a culvert? #18
I installed my first culvert in 1989. I've never had a failure or washout. In fact I've replaced some galvanized culverts that I installed years ago that have rusted out. I now use dual wall plastic on all but those over 4ft diameter. I've installed culverts in all sizes from 12" to 96" in lengths from 20ft to 120ft. I've never used a tamper or hand tamped. If doing a large culvert I dig the trench double the width of the culvert and place it in the middle. On a small culvert like the OP is installing there's no concern about that. Use whatever method makes you feel good. :)
I'll see if it's decent enough to work on after work. Back fill the little bit I need & tamp that a bit. Thinking I'll use some of the pile of pea gravel I have left to bed it in a little bit. That will pack in without being tamped. Either dump some dirty sand on that to lock it in or just use the pile of dirt & drive over with the tractor to tamp the top.
It's not going to get a lot of flow, especially until I re-grade my other section of driveway (it will just continue eroding the wrong side of that driveway branch & dumping sediment in my main driveway about where the other end of the backhoe you couldn't see in the photos was parked.
   / How much tamping required for a culvert? #20
2016 Ford F-450XL (A53314)
2016 Ford F-450XL...
2011 Ford Explorer SUV (A55758)
2011 Ford Explorer...
Kennco Bed Shaper (A53314)
Kennco Bed Shaper...
58" 3pt Snowblower (A50775)
58" 3pt Snowblower...
Miller Bobcat 250 Diesel Welder (A54865)
Miller Bobcat 250...
2001 International 4700 Dump Truck, VIN # 1HTSCAAM51H379512 (A54865)
2001 International...
