Shop lights
/ Shop lights #1
joeu235
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
Anyone have any experience or recommendations for picking out shop lights?
40 x 40 area with 14 ft ceiling.
/ Shop lights #2
I had a bunch of 8' t8 light fixtures (4 four foot bulbs not the 8 foot ones) I ordered replacement led light bulbs. Very easy to install, just make sure if you order them that you get the ones that can be used without the ballast. I installed 3 fixtures in each bay and its very bright, about twice as bright it seems compared to the old compact florescent. My ceiling is also 14'
Rust
/ Shop lights #3
I have a 40 x 48 building with 12 foot ceiling. I have an array of about 23 (if I remember correctly) 4 foot shop lights (2 bulbs each). I set it up based on the criteria (assuming 40 watts per bulb, old T12 style) of a minimum of 1/2 watt per square foot for storage areas, 1 watt per square foot for general work areas and up to 2 watts per square foot for bench work areas. I actually have T8 bulbs which give more light with less wattage and if you go with LEDs, you will get even more efficiency, but the 80 watts per two light shop fixture works for calculating fixture requirements even if you are using less power.
I'd like to have LEDs but I buy the cheap T8 fixtures from Menards. Over the last 5 years, I've had three of them fail, but they are so cheap I'm still money ahead. Not that much hassle for me to replace them. Fluorescent bulbs seem expensive, but when you buy them by the case, they aren't very costly. I haven't burned any bulbs out except for a couple of used ones I put in to start with.
/ Shop lights #4
For a new installation LED's are the best choice. They are more expensive to buy than a florescent but they produce more light, last longer, and use less power.
/ Shop lights #5
I put lights in a 30x40x12 shop last year, I used 4x 50w 6000k LED on about 10' centers fixtures to light one side and they worked very well. I would do that again in a heartbeat.
Aaron Z
/ Shop lights #6
When I built my shop 20 years ago, LED technology wasn't near as developed as today....and given the energy savings, I'd probably give them a look for sure....LOVE the Cree LEDs we put in the house.
But for blazing white, near day lights, it's hard to beat metal halide. I put 4 of the 'low bay' versions in my shop, difference being the high bay (like 20'+) use a smaller, cone reflector, the low bay uses a 2' diameter, more shallow reflector...the transformer base is the same.
I put 400w bulbs in mine, and the first one burned out just a few weeks ago....so I got over 20 years out of the bulb. After seeing how much brighter that one bulb was compared to the other 3, I replaced them as well. Apparently, they degrade over time, not just go all at once.
The inside of the shop is Knock-your-eyeballs-out bright....I'd hate to think how many flourescent tubes it would take to do this. The shop is 35x64 in that part, the upper part of the flat ceiling is 24' across, sheetrock with gloss white paint on top.....that helps too.
They do take about 4-5 minutes to come up to 'full bright'....this photo is with them about 1/2 way:
(I also put a few regular can lights down the center on a different switch so if I want to just go in for something quick, they give me enough instant light to see my way around)
ry%3D400
This is full bright:
ry%3D400
/ Shop lights #7
TnAndy's shop lights are awesome!!!!!
I don't pay much attention to folks claiming exceptional lighting without posting pics...... Too much room for opinion.
Look closely at TnAndy's pic. Pay particular attention to shadows under the equipment. Don't see one do you...... That's quality lighting.
Here's a pic of my shop lighted with 4' T8s, 4 bulbs per fixture, 8 fixtures in a 42x50 shop.
/ Shop lights #8
LED shop lights have come way down in cost.
/ Shop lights
Thanks for the input. Anything will be better than my current lighting.
/ Shop lights #10
Yep. They are crashing in cost so fast that what you buy today will be overpriced in a month!!!!
I think you should just buy what works for you. We each require a different level of light for the particular work we are doing and our personal sight. My shop works for me. But if I was building again today, I'd look real hard at LED.
The only thing I don't like about the metal halide is their slowness to come to full brightness. Small trade off for their exceptional light.
/ Shop lights #11
I'm really impressed with my Costco 4ft LEDs. Mounted them close to a year ago and love them. Installed 6 in my 2+ bay shop and just bought two more for grins because they are now only $20ea. Should buy a few more as I plan to expand my shop and really like the light output vs. wattage, instant on, and bulb life.
/ Shop lights #12
I cheated. I got 20 of the old fashioned 8 foot fluorescent double fixtures, with bulbs and spares, for FREE. They were old, but they work fine.
Then I got 10 of the 2x4 foot surface mount 4 bulb (T8) fixtures, BRAND NEW, with bulbs and yes, spares. Free.
I love Craigslist! :D
/ Shop lights #13
OK, here are some photos of my arrangement, showing the storage area and the bench area. I may have overdone it a bit but my old eyes like a lot of light. I went with the fluorescents when I did it 5 years ago but I would probably bite the bullet and go LED today.
/ Shop lights #14
A friend of mine bought a bunch of the Snap-On Work Lamps and wired a plug receptacle into the ceiling box and screwed the lamp to the ceiling and plugged it in. He was able to aim the beam where he wanted and custom place the lamp where he wanted it, with the length of cord on the Work Lamp.
/ Shop lights #15
For that height T5 fluorescents can be a really good way to go. That is what I did for my 13' ceiling. For the "shop" side of the building I put in 9 8' T5 fixtures, each of which is essentially a pair of 4' fixtures stuck end to end. 4x 4' T5 bulbs for each. The shop is 32' wide and 50' long. Light are oriented along the long axis, in a 3x3 grid. It is not burn-your-retinas bright, but I am very pleased with the results. I got mine from a commercial lighting supplier that is partly owned by a friend of a friend. I got much better pricing than HD, for example and that included the bulbs even. Better quality ballasts too. I have no need for additional lighting unless I am doing something practically microscopic.
You can see 6 of the 9 in this photo.
/ Shop lights #16
This is what you need to calculate the lighting. The internet is full of guidelines for amount of lumens per sf. It will depend on if you want general lighting, task lighting etc. Once you get an idea of how much light you want use this tool-
Visual Interior Tool
This doc will provide a good understanding of the amount of light you will want. Focus on indoor section starting about the middle of the doc.
https://www.noao.edu/education/QLTkit/ACTIVITY_Documents/Safety/LightLevels_outdoor+indoor.pdf
/ Shop lights #17
I converted to the Costco LED bulbs...
Garage is 24 x 30 and had four 3 bulb T12 fixtures that were circa 1960.
Popped in 2 48" Costco LED and the light level is fantastic... sometimes I turn them on just to impress myself.
I also have a single 8' T12 over the bench in a glass diffuser... thought it was two 48" until I opened it up.
/ Shop lights #18
I don't think you can beat the $20 costco led shop light fixtures. Come on to full brightness instantly no matter the temperature, easy to install flush on the ceiling and very light weight. I did have one partially fail a couple of months after installing it, costco reimbursed my purchase cost and the replacement was $10 less.
/ Shop lights #19
The only thing that beats my $35 Costco LED lights are the $20 ones now.
/ Shop lights #20
View attachment 492953View attachment 492954
KennyG;
Nice set up; I'm wondering, can you even cast a shadow in there.:)
That place is well lit.
I wanted to try out the 4' LED lights so I put a couple over my work bench. Here is a night time shot.
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
UNUSED AGT 12EX-ATA MINI EXCAVATOR (A64281)
UNUSED AGT...
2025 JMR Stump Bucket Skid Steer Attachment (A61572)
2025 JMR Stump...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64279)
KNOW BEFORE YOU...
2014 FREIGHTLINER CASCADIA 125 T/A SLEEPER TRACTOR/TRUCK (A59912)
2014 FREIGHTLINER...
Caterpillar D6 Dozer Service and Parts Manuals (A63117)
Caterpillar D6...
