Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #2,181
/ Let's talk flail mowers #2,182
And speaking of flail mowers, I'm working on some field clearing and when I get done I have what amounts to a hairy field with all the roots sticking out.
Do you think my flail (Caroni TM1900) would mow these roots? Or would that be flail abuse?
/ Let's talk flail mowers #2,184
Asssuming you have the finish flail mower rotor with four rows of side slicers I do not see a problem
AS LONG AS you back over them to the very end of th eland clearing and then crive forward over them.
Do you have a belly brush guard to protect tthe underside of the mule?? I would be more worried about
that first and formost!!
/ Let's talk flail mowers #2,185
/ Let's talk flail mowers #2,186
Does someone here know what model Vrisimo flail this is that showed up on my local CL? It's listed as an "8 foot" cutter, though that may be its overall width. It looks to be a precursor to the current Super Series. The most distinctive feature is what appears to be a completely rounded belt housing top with vents. Would parts be available for it? I'm trying to decide if it's worth the 3 hour round trip to scope it out. Thanks.
It should be a 3 row finish flail mower and well worth the trip.
Parts are still available as the majority of them are generic-i.e,,
The V belts are metric, the bearings are metric and the knives are
available from several sources,the manufacturer is in California
and still in business.
It will only need a new PTO shaft, a new set of kevlar belts, and few new knives,
but still worth the trip as you are looking at almost 5 figures with tax if new in that size mower frame.
Check to see if the ID plate is either on the box weldment, bottom of the mower shroud or under the V belt guard to find the serial number.
/ Let's talk flail mowers #2,187
So are you saying, you've gotten to the root of the problem? :)
<b0728017>
UGH!!!! that was bad even on Eastern Standard Time.
/ Let's talk flail mowers #2,189
And speaking of flail mowers, I'm working on some field clearing and when I get done I have what amounts to a hairy field with all the roots sticking out. http://s255.photobucket.com/user/hu...lina/NEW FIELDS/IMG_3002_zpsu0rmz7e3.jpg.html Do you think my flail (Caroni TM1900) would mow these roots? Or would that be flail abuse?
There are a couple of stumps in there that I'd go slowly over but the majority of the stuff sticking up would be easy work for a TM1900.
/ Let's talk flail mowers #2,190
You are most welcome. please notify my organization through the forum here
if and when you make the purchase so I may welcome you as the newest member
of the "Flail Mower Nations".
/ Let's talk flail mowers #2,191
Ok, Island Tractor, Leonz, and Gmanbart... I've been following this conversation about gradient pressures ect since it started. Now I'm just trying to make sense of all this. Nobody is mowing turkey feathers anyway right?
So I'm thinking... what you guys are trying to determine here is " do our flail mowers suck" is this correct?:laughing:
WEEEELLLLLL,
As Bucky Cat from the cartoon "Get Fuzzy" would say "that Hoovers".
I am going to order my Dwyer Vacuum Gauge this week to solve this issue.
My Lawn Genie' chute/flue/duct to the collection basket is approximately 8 inches tall by 48 inches wide by 48 inches long before it exits into the collection basket so I know it is moving huge amounts of air through it when collecting crass clippings while mowing or picking up fresh clippings after they have dried somewhat.
/ Let's talk flail mowers #2,193
We may need to have a second version of the T shirt for Gman: "My flail is suckless":eek:
Forestry flail mowers "suck less" too as they have a cast flail head that is one piece with either a solid cast rotor with rings with serated cutting edges or replacable cutting bits.
:eek::cloud9::drink:
/ Let's talk flail mowers #2,194
"Forestry" flail mowers are so different from "grass and brush" flail mowers as to be a separate species altogether. The forestry "flails" basically beat large vegetal things to pieces rather than slice or cut them. Kind of like comparing a bush hog to a reel mower.
/ Let's talk flail mowers #2,195
I think mine would say "My flail sucks less than yours"....
I'm considering color coding, and numbering grass cuttings, then carefully placing them on a numbered grid square, noting all of the cuttings with their numbered coordinates, then going over the whole thing with a flail. Of course, we'll need hi-speed video of everything, so I'll see if I can borrow a GoPro from work, and find a way to mount it under the Sicma. Adding pressure gauges to that would just be showing off...
/ Let's talk flail mowers #2,198
Noticed the state road guys were cutting near the house today and seen where they "mowed" a log (Had an Alamo flail on the tractor with the Y blade knives)
Thought it was interesting to see how it "cut" the log (about an 8" log so not really brush in most peoples eyes) and thought others maybe interested in...
/ Let's talk flail mowers #2,199
I have some big roots in some of my trails like that.. I'll take a pic sometime..
/ Let's talk flail mowers #2,200
I tried my flail for the first time today... I greased it up and got it to rotate with little resistance. So I tried to cut with it and it wouldn't cut anything. The roller did a great job of laying things down. Here is a video of it hooked up and running. I need to get a longer pto shaft as you can see there isn't great contact between the shafts. I'll post some pics of the grass I tried cut. The blades are in bad shape, but I would have thought from shear force they would have cut something
Flail: http://youtu.be/N6p8MP3TYNU
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2013 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A64279)
2013 KUBOTA KX71-3...
2012 Chevrolet Silverado 1500 Hybrid Crew Cab Pickup Truck (A61573)
2012 Chevrolet...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
1600 GALLON T/A NURSE TANK (A63291)
1600 GALLON T/A...
2005 Nissan Frontier Crew Cab Pickup Truck (A61573)
2005 Nissan...
