Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #2,161
AH, it is so nice to have my findings proved once more. Thank you Island Tractor.
My Mathews lawn genie has 2 air paddles attached to the flail mower rotor which is almost
six inches in diameter which aid in lifting the clippings up an over the flail mower rotor and
also aid in lifting the clippings into the collection basket while mowing or picking up clippings
that are longer in length due to rain preventing ones mowing as desired.
After I obtain my Dwyer vacuum gauge and tachometer I will take a reading to see how much
of a pressure gradient is generated at full throttle and with the rotor speed of 2,200-2300 RPM.
/ Let's talk flail mowers #2,162
Nice video. Not so sure about attributing the difference in cut just to "mechanical effect" though. FYI, I just googled flail mower and vacuum and found that several major manufacturers mention the "vacuum effect" in their sales literature. Vrisimo - Super Series Flail Mower Heavy Duty Brush Cutting Tractor Mounted /Tow Behind Flail Mowers 403 Forbidden John Deere materials also mention "vacuum" with their flail mowers/shredders.
Not exactly experimental data but these promotional materials do fit with the notion that flails cut better when riding on their roller in close proximity to the ground due at least partly to a vacuum effect.
The only mention I saw of suction was when they were talking about flails with scoop knives, but I didn't try to go over every line. Then again, we know that promotional materials are always based upon scientific data right? :laughing:
Well, just don't tell them that LouieJunior can't move feathers with his flail...
/ Let's talk flail mowers #2,163
Findings are what you get after testing.....sounds like you're still at the theory stage. As LouieJunior noted, his flail couldn't pick up and mulch a feather. If a flail can't pick up a feather, there can't be enough pressure gradient or suction to make much difference.
If a standard flail could generate enough pressure/suction, your Mathews wouldn't need those air paddles.
The only readings that would be of any significance are with the PTO running at 540rpm and with the flail stopped. Also, you'd have to take readings in at least four different places for it to mean anything....in front of the rotor, behind the rotor, top and bottom.
/ Let's talk flail mowers #2,164
Using a Dwyer vacuum gauge in a flue connection or a duct which essentially
is what the flail mower shroud is. It is not difficult as all that is needed is a small
drilled hole in the flue is where the readings are taken.
The metal tube which is connected to the rubber hose is inserted in the flue or duct
and the measurement taken for the pressure gradient created "at work with the furnace or
boilers forced draft fan which forces air into and over the burner or through the coal stokers flat grate where the combustion air exits through the holes drilled through the grates and then in to the combustion chamber and then out of the flue into the chimney.
There is actually one place where the readings would be relevant with
regard to the pressure gradient which is the air duct exiting the flail mower rotor where
the air flow travels into the collection hopper.
A couple for things to keep in mind are:
The flail mowers rotor depends on ground effect to a certain extent(which is death for helicopters because they cannot maintain or obtain massive amounts of lift near the ground surface)
The front of the flail mower rotor and the back of the flail mower rotor are the entry and exit points for
the air flow(with the diverter door shut).
The mowers height which is regulated by the rear roller in some flail mowers and the wheel set on my lawn genie are what creates the amount of opening that exists in front of the flail mower rotor.
The height of the mower shroud including the rubber skirt in front of the mower(in my case) or in the case of the debris guard in the case of the Sicma flail mower brand and others is which is going to affect the surrounding airs ability to enter the flail mower shroud.
In the case of the lawn genie the twin air paddles are what aid the flail mower to carry the clippings up the sheet metal duct and into the collection basket and aid in carrying heavy amounts of clippings over the flail mower rotor and into the collection basket.
(the same could be said for the forged scoop knives and the trash door on the Land Pride/Maschio flail mower where the open trash door aids in discharging the clippings quickly in heavy brush mowing conditions)
The Lawn Genie collection basket also has a full width screened vent that is a foot long and four feet wide that releases the pressure gradient/air flow created by the flail mowers side slicer knives and the air paddles and the air disturbance created by the clippings entering the collection basket at the same time.
The only real relevant location for a vacuum gauge reading is in the location above the diverter door
above the flail mower rotor as the sheet metal duct is which directs the clippings into the collection hopper is the furnace flue essentially in the example.
Saying that: feeling and seeing the amount of air and mower chaff/dust moved by the twin air paddles and aerodynamic lift created by the tapered side slicer knives which are also lifting the air into the shroud and into the duct above the diverter door is huge.
The collection basket does not interfere with the clippings like a vacuum bag as the air flow exits directly up and out of the collection basket through the screened opening in the roof of the collection basket.
I will get the ambition to use a smoke generator stick later in the summer to aid in explaining this physics problem (I hope).
Its time for my Perry Mason episode hour and to quote former United States Army General Douglas Macarthur "I will return".
It is always fun to talk about anyway.
/ Let's talk flail mowers #2,165
The only mention I saw of suction was when they were talking about flails with scoop knives, but I didn't try to go over every line. Then again, we know that promotional materials are always based upon scientific data right? :laughing: Well, just don't tell them that LouieJunior can't move feathers with his flail...
Promotional materials certainly are not scientific data as I acknowledged earlier. On the other hand, when JD and Vrismo, both major and competing flail manufacturers, describe vacuum as a significant element in improved cut quality (not only with scoop knives though perhaps more with scoops), I would at least say that the burden of proof shifts towards the naysayers. Perhaps it is simply a flail industry fiction but vacuum or pressure gradient seems to be discussed as important in a number of other types of rotary mowers too so the idea it is important for flails is not exactly without precedent.
/ Let's talk flail mowers #2,166
I went through all those links more carefully, and the only mention of suction/vacuum is when they talk about scoop or cup shaped knives. A knife shaped that way will definitely move air as it has a large cross-section...they are reasonable fan blades at that point.
"All Super Series Flail Mowers come standard with fine cut scoop knives that create a vacuum effect, lifting debris and vegetation into the unit for improved mulching."
"High-vacuum cupped knives create plenty of suction to draw material up off the ground, assuring neat and thorough mowing and shredding."
I have yet to see a reference to the same thing with side slicer knives....almost certainly because they're thin, sharp, and aren't capable of moving much air at all.
Theory is interesting, but when somebody puts their flail over the top of a feather, and it can't lift it, the theory doesn't matter much.
/ Let's talk flail mowers #2,167
/ Let's talk flail mowers #2,168
As i have mentioned previously;
the knife hangers for the matthews lawn genie permit the slotted
mounting hole side slicer knife to become an aerfoil when the speed
of rotation is fast enough to allow the tapered leading edge of this specific
side slicer knife to become an airfoil and travel horizonatally in flight even
though it is traveling in a circle.
These side slicer knife pairs make tremendous racket when the flail mower rotor slows
permitting them to fall ue to the effects of gravity.
currently available knife mounting systems do not do this as the knife pairs are restrained by the
mounting bolts and the narrowed distance between the mounting station weldments.
/ Let's talk flail mowers #2,169
Even if that's true, I don't think most folks have a Mathews Lawn Genie...haven't really seen any mention of them other than your references.
/ Let's talk flail mowers #2,170
Hello GmanBart,
I have but cannot upload the manual for the
36-48-60 inch lawn genies but I can send it to anyone
who would like one.
I will try and copy and upload a few of the relevant pages for all of you.
/ Let's talk flail mowers #2,171
So, I guess the upshot is I should fashion a rear debris shield for my Mott SHD88 flail? Right now it's open, just as I bought it a couple years ago well used. It does produce (and spread all over) lots of fine clippings, and cuts grass very well as is. The rear is open about 8-10" so I guess it doesn't develop much of a gradient, if its supposed to.
It would be great not to emerge from mowing with inches of clippings on the mower, drawbar, PTO shield, etc.
This is one section not cleaned off yet, after one hour cutting 16" grasses.
Jim
/ Let's talk flail mowers #2,172
Just checked, and it's 13" open. Guess I'll close itin and see how that works.
Jim. Hmm, hope to get rid of 2nd pic
/ Let's talk flail mowers #2,174
Get a piece of old conveyor belt and bolt it on. They also sell a "rubber" flap for it. That is what mine came with but I still get chaff on the top because my roller is set high.
/ Let's talk flail mowers #2,175
Here you go GMan, an honest to goodness experimental data containing article that looks at power needed to generate rotation and VACUUM in a commercial flail mower. You might have fun working out the calculations to double check theirs.
Note that while this article (PDF link below) is in reference to a commercial flail, the drawings indicate they are using the typical Y style blades not the scoop blades. And, all kidding aside, virtually ANY blade and mount will generate rotation of air when spinning at 60-90 mph.
"a model for determining the power in kW at the PTO:"
(SORRY TBN cut and paste didn't include the elegant equation but you can see it in the article here: http://www.scielo.cl/pdf/ciagr/v36n1/art05.pdf)
where, n is the total number of cutting blades, p the air density (p = 1,225 kgキm-3), Fa the surface facing the air during the cutting blades' move-ment (m2), Cx the non-dimensional coefficient of air resistance that includes the effects of the cutting blade shape (Cx = 0,1.. .1), R the radius of the extreme cutting blades (m), r the ratio of the cutting apparatus of the shredder (m), ωthe angular speed of the cutting apparatus (rad-s-1), Y the mass of remnants in humid base (kgキm-2), B the width of machine work (m), V the shredder's work speed (mキs-1), M? the moment of the friction force in the supports (Nm), ns the number of cutting blades cutting the stemキssimultaneously, ε the work consumed for cutting per area unit (Jキm-2), bc the projection in the horizontal plane of the cut width of a cutting blade (m), k the relationship between the actual cutting area and the working area, Rh the distance from the rotor's cutting zone (m), and η PTO PTO the efficiency of the transmission from the tractor's PTO to the cutting mechanism of the shredder.
The equation that determines the power needed to overcome the opposing forces during the vacuum work (air resistance and friction in the supports of the cut mechanism) and the power needed to make the technological process (cutting and spreading of the shredded material) can be stated as:
(SEE PDF for equation)
where a, c, b and d are coefficients related to the power losses by air resistance, spread of shredded material, and the moment of the friction force in the supports and cut, respectively.
Have fun!:thumbsup:
/ Let's talk flail mowers #2,176
GMan, found an article for you with real live experimental data to determine power needed to generate both rotation and vacuum with a flail mower. Get out your calculator to check their math.
Have fun!:thumbsup:
You do realize that they never mention anything about "vacuum" right? They compare friction losses to two different kinds of blades...that's the "air resistance" part. They're actually quite clear when they compare the mechanical resistance caused by throwing the cut material over the rotor....their term, not mine. Notice they describe it as a mechanical throwing, not a pressure-related movement. They also point out how that's all controlled by the rotation speed, the blade size/type, and the ground speed or feed rate of the cut material. No mention of pressure gradients at all....funny.
A blade the size and shape of a typical Y flail blade will generate minimal air movement, which is why they won't generate enough air movement to lift a feather....pretty low standard really. Will it move some air? Sure, but it's not much.
The next time you're driving on the highway, lower the window, and put your hand out into the breeze at whatever legal speed is there....in the 60-90mph range like you mentioned above. Keep your hand on edge and see how much resistance you feel. Then imagine the resistance being something like 1/10th of that (hands and arms aren't sharp/smooth, and are far larger in total cross-section).
/ Let's talk flail mowers #2,177
Does someone here know what model Vrisimo flail this is that showed up on my local CL? It's listed as an "8 foot" cutter, though that may be its overall width. It looks to be a precursor to the current Super Series. The most distinctive feature is what appears to be a completely rounded belt housing top with vents. Would parts be available for it? I'm trying to decide if it's worth the 3 hour round trip to scope it out. Thanks.
/ Let's talk flail mowers #2,178
1) It was mostly a joke, I just loved the equation. This article doesn't directly address our question.
2) Next time you are driving down the highway at 60-90mph, hold out 50-100 1/8"x3" blades plus the surface area of mounting points and clevises etc. I suspect it would generate quite a bit of resistance (and low pressure area behind).
3) In the article discussion they state:
"The results obtained in this investigation, the
analysis of the linear and cubic components for
the demand of the vacuum power and the linear
and quadratic components for the power of the
technological process, as well as the influence
of the angular speed of the cutting mechanism
with respect to those components (Figures 3, 4
and 5) have not been reported in the literature
so far."
I'm neither a physicist nor mechanical engineer but my suspicion is that other than the power needed to actually cut the vegetal matter, a good portion (well at least some) of the PTO power needed to run a flail at operating speed (while not actually cutting for example) is the power needed to move the air (which generates vacuum). The rest would be mechanical friction losses.
Maybe we'll have to call an engineer at Vrismo or JD to see what they have to say.....;)
/ Let's talk flail mowers #2,179
Ok, Island Tractor, Leonz, and Gmanbart... I've been following this conversation about gradient pressures ect since it started. Now I'm just trying to make sense of all this. Nobody is mowing turkey feathers anyway right?
So I'm thinking... what you guys are trying to determine here is " do our flail mowers suck" is this correct?:laughing:
/ Let's talk flail mowers #2,180
Ok, Island Tractor, Leonz, and Gmanbart... I've been following this conversation about gradient pressures ect since it started. Now I'm just trying to make sense of all this. Nobody is mowing turkey feathers anyway right? So I'm thinking... what you guys are trying to determine here is " do our flail mowers suck" is this correct?:laughing:
You got it! I need a tee shirt that says "My flail sucks"
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
2015 GMC 3500HD Flatbed Truck  6.6L Duramax Diesel (A63688)
2015 GMC 3500HD...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
NEW CHILDS METAL WAGON (A64281)
NEW CHILDS METAL...
case 370 glass door never installed (A61307)
case 370 glass...
