When to replace chainsaw file
/ When to replace chainsaw file #21
if the cutting teeth are not work hardened , you can get a lot of mileage from 1 file.... but as it gets used, it takes a bit more each time to do a good job .... BTW, stopping frequently and touching up the teeth can actually extend the life of the chain too....
anyway , do what you "feel" is best for you ... 3 strokes , 10 strokes... all personal preference .... and experience .... some need more , some less ...
just try not to work with a dull tool of any sort.... just makes things harder and longer to do.:)
Teeth get "Work hardened"? Does this happen? Or are chains tempered (softened) when they are over-heated and slowly cool?
/ When to replace chainsaw file #23
I do what has already been mentioned over a few posts:
--buy them by the dozen and don't try for too much mileage
--I use a holder to judge the angle and mark the handle end. Normally get about two sharpenings before turning it 90 degrees for another two for about 4 sharpenings per file.
I also have to resist the tendency to over-use sandpaper disks. At some point it becomes counter productive, even at $0.00 per hour!
/ When to replace chainsaw file #24
the dull teeth get very hot then cool quickly when you stop ( chain sitting in a big steel bar heat sink ... remember ) .. the tips get very hard and you actually need a stone to sharpen them afterwards .... .... stopping before it gets dull (and hot ) keeps the teeth softer and easier to file ....
Very interesting. Good info. :thumbsup: I think we've moved beyond Chain Sharpening 101 and are learning more advanced Chain Sharpening 213 info.
/ When to replace chainsaw file #26
I don't know if you can go by me as I was strictly into production. When I was working, I'd use a file 6 times. This included touch ups and occasional ding repairs. To this day as a regular homeowner, I still use it to file 6 times. I just like the cut going faster with a few strokes rather than too many multiple strokes to get to the same place.
/ When to replace chainsaw file #27
:thumbsup: ding or dong , touch the ground /rock , etc ... stop and touch up the blade ...
continuing to "cut any way" just costs you more time down the road ....
/ When to replace chainsaw file #28
4-6 sharpenings?! I must have about 25-50 on mine. I guess I've got my money's worth out of it and can afford to splurge $1.45 on another. Heck, maybe even two!
Even when I'm "just going to touch it up", "2-3 strokes each", somehow I end up taking 5-7 on each tooth until it "feels" right. Don't know why I do this. :confused3:
You do it because you are using a dull file. 25 chains, much less 50 are way over the life of a file.
Harry K
/ When to replace chainsaw file #29
With a sharp file you will get the chain sharper, quicker & be more accurate with angles and such.
You do it because you are using a dull file. 25 chains, much less 50 are way over the life of a file. Harry K
Yes! "I see the light" said the blind man. FINALLY grabbed a new file. Wow, what a difference. 3 zips and done.
/ When to replace chainsaw file #31
I replace my chainsaw file when after filing, I'm still cutting feather sawdust.
I replace my chain after filing it about 10 or 12 times, or if I break more than one tooth, which for me is somewhere between 6 and 12 months.
I replace the bar if it gets bent, or a rivet loosens up.
I replace the chainsaw if I blow a cylinder. Haven't had that problem since I stopped buying the El Cheapo light saws made for the occasional user and started buying the larger, 'logging' grade saws.
Only had a cylinder blown on one Husky and that was a factory defect - they replaced it free. Of course I did have to replace one chainsaw that I had pinched when a tree came down and twisted, and just before coming to rest, released the saw and rolled over it, turning it into $500 worth of metal and plastic confetti. Only time I ever cried cutting trees.
/ When to replace chainsaw file #32
I hate to think about the many years I spent fighting files before I learned the lesson.
Harry K
/ When to replace chainsaw file #33
I started using these diamond coated burrs about a year ago and am really pleased with how well they work. I have one in a corded Dremel tool in the shop and a second in a battery powered Dremel tool for quick touch ups in the field. They come in a 4 pack and I am still on my first two.
I used to use the Dremel brand "stone" sharpening burrs but they would usually break off tip before getting complete chain sharpened.
4 PC 5 32" Diamond Chainsaw Sharpener Burr Stone File Fits Dremel 1453 | eBay
Sent from my iPad using TractorByNet
/ When to replace chainsaw file #34
I agree, it is much easier to keep consistent angles with a sharp file.
/ When to replace chainsaw file #35
After the push, and the feel of the bite I always look at the tooth for a good bite, I also use a file comb on all my files.. best of all they pull double duty by removing lint on Velcro tabs and such..
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
PREVIEW DATES AND TIMES (A65583)
PREVIEW DATES AND...
John Deere D110 Riding Mower (A62679)
John Deere D110...
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
Harlo HP6500 (A60462)
