Bridge#2
/ Bridge#2
Looks real nice. I'd be interested to know how much deflection there is when you have a fully loaded machine and trailer on the middle of it. Should be easy enough to measure.
I've been wandering the same thing, I may try it later today with the K and the fel loaded, that should give me an idea.
/ Bridge#2
Ok, did the test...the first pic is of the bridge empty, made a mark and didn't move the stick. The second pic is with the bridge loaded (the K with the fel fully loaded and a box blade on the back), made the second mark and turned the stick around. The third pic is of the K loaded in the middle of the largest span. The deflection is 1/8 of an inch. That kinda surprised me, I didn't think there would be any. You can't feel any give when you drive on it, it feels solid as a rock. Thanks for suggesting the test. I'm not sure how much it should deflect, but I feel ok with it.
/ Bridge#2
Very nice, "Bridgeman"! I like the look. Watch that poison ivy!:eek::D
Jay
Funny you should mention that...me and the dog both got poison ivy. I've lived in the country all my life and i've never even heard of a dog getting poison ivy. She did!!! broke out all over, weirdest thing i've ever seen. She had little bumps all over her body that made her hair stick-up...it made her look like a cartoon dog that just got wupped-up on by Mighty Dog. We took her to the vet, and they confirmed it, gave her a shot and some pills, and pretty much told us its fairly common for dogs to get it. That was a first for me. Wish i'd taken pics of her...She was weird looking. It cleared-up the next day, she's fine. I sure learned something that day...lol.
/ Bridge#2 #127
You should do some commercials for a drill manufacturer.
That was alot of holes to drill!
/ Bridge#2 #128
Wow! I've never heard of them getting it either. We always assumed that we could get it from them if they rubbed up against it and got it on their hair. I mentioned it because I thought I saw it in the lower left corner of the 3rd pic. On the right looked like Virginia creeper...I think. Anyway, "leaves of three, leave it be"!:D
Jay
/ Bridge#2 #130
OK Buggy,....better document the "fort" too,...should be interesting for a whole lot of us. But I'm looking forward to the kitchen project when you get to it. By the way,...you (and the bricklayer) do some pretty nice work !!
CHEERS!
. . tug
/ Bridge#2
CHEERS!
. . tug
Thanks...I will document the fort, and the kitchen.
/ Bridge#2 #134
What does L/2400 mean?
That your deflection expressed as a fraction of the span e.g. 1/400 or 1/600. Either the strength limit state (allowable stress) or the serviceability limit state (deflection considerations amongst others) may govern the minimum dimensions of the member required. The deflection must be considered for the purpose of the structure. I'd bet that the static (dead load) deflection excedes the (live load) deflection.
/ Bridge#2 #135
If you want to check Total deflection, pull a dry line VERY tight along the bottom web with the bridge empty. You'll have to block it down 3/4" on the ends. Then measure the gap at midspan and subtract that from the 3/4" blocks. Paint that number down under the bridge somewhere along with the date. That will give you a base line for checking for future inspections. Add your 1/8" and that will give you total deflection.
/ Bridge#2 #136
The bridge looks great.. and you did an excellent job!:D
/ Bridge#2 #137
1/8"!!! Transit would mark that as a failure!
(just kidding Transit)
The 1/8 inch deflection is not what I was concerned about. Remember the Oakland Bridge in California that was closed this weekend? Did you see the Dog Bone Link that cracked at the Eye? That crack was the result of stress-concentration as opposed to average stress. That type of crack starts at the inside of the hole [a point of discontinuity] that the link-pin secures and works its way outward.[ first discussed in 1864 by Barre de Saint-Venant] Now that bridge and its components are many times stronger than it has to be [safety factor] and that link could have completely failed, other links in the catenaries would have safely taken up the extra load. Drill holes in the wrong place and you setup a very local overload that will fail some day. I could bore you for hours with the details of Mores Circle, Dynamic and repeated loading, etc.
Bottom line is, Buggyman ends up in the ditch crushed with the tractor on him.
PS, not kidding. :eek:
/ Bridge#2 #139
Geeee....... I wonder why that failed? Oh, wait ...I think I might have an Idea. The bridge opened in 1936 and has appox 270,000 cycles per day. That would be 719,415,000 cycles before stress failure. :rolleyes:
/ Bridge#2 #140
Ya think buggyman can make that many trips over the bridge in the next 50 years? Guess he'd better quit his day job.
Very good point.. Nice way to put it into perspective.
Wedge
Unused 2022 Land Pride 1006NT 10ft. Pull Behind Grain Drill Tractor Attachment (A66734)
Unused 2022 Land...
1992 International 4700 1,200 Gallon Fuel Tanker Truck (A66736)
1992 International...
2011 Lexus IS250 Sedan (A66738)
2011 Lexus IS250...
2025 JMR Stump Bucket Mini Skid Steer Attachment (A66734)
2025 JMR Stump...
WARREN POWER SYSTEM LIGHT PLANT (INOPERABLE) (A68842)
WARREN POWER...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
