2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,575
Traditionally, creek crossings got built from whatever decay resistant timber was locally at hand. Then rot took its toll and the crossing had to be reworked. That is why over time as people around here could afford it, they switched to I beams and concrete for its durability and lack of maintenance.I built a similar bridge 10 foot span, out of two 8x8 hemlock beams and 2x8 hemlock decking about 10 years ago. at the time I had my b7800 and it worked OK but over the years one beam failed due to rot.
I just rebuilt it with steel beams doubled up so i used two steel beams per side so four beams total with the same size 2x8 decking. they are six inch steel beams I think W15 (not sure) I doubled them up to match tire tread widths of all my stuff ranging from ATV to an old manure spreader used as a wood trailer that is wider than the tractor.
I also more than doubled my tractor weight in those ten years. b7800 was approx 3000 with a loader and my L4740 is atleast close to 8000lbs with the loader and filled tires. I get what feels like zero deflection when I cross the steel frame bridge with my L4740.
I hate doing stuff twice. my time is worth something, I vote for steel especially for your longer span.
Whatever an I beam costs today, it will probably cost a lot more 10 - 15 years from now after wood has rotted out and needs to be replaced.
