WKY Horse Barn
/ WKY Horse Barn
Setting last 2 trusses.
/ WKY Horse Barn
Rolling last truss into vertical.
/ WKY Horse Barn
Starting lath.
/ WKY Horse Barn
Using a hard spacer to make sure the trusses are on center. This idea worked well & actually caught a layout problem before it got too bad.
/ WKY Horse Barn
Finishing lath & fascia board.
/ WKY Horse Barn
Last high fascia board.
/ WKY Horse Barn
The barn is all Topped out & the flag is flying!
Here's the finished framing. All trusses up, lath & fascia finished ready for roof & siding metal. Of course there's some diagonal bracing & all the interior stuff to finish but this is a huge milestone for us.
/ WKY Horse Barn
Here we are working on the high roof on the North side. Until about 2 it was cloudy with almost no wind so handling the foil insulation & the metal roof sheets wasn’t bad @ all. I’m the one the left & yes, I’m wearing a full body harness tied off.
/ WKY Horse Barn
This is the last sheet on the high North roof. It wasn’t very fun to get this one in since there was no place to stand but on the next to last sheet. My buddy held tight onto my lanyard to help give me some “confidence tension” while I walked around, carefully screwing down the sheet.
/ WKY Horse Barn
Another view of the last sheet on the North high roof getting screwed down. I really did not like reaching out to get the last 8 screws in!
/ WKY Horse Barn
After lunch the wind came up & it was just too dangerous to work on the South high roof, so we moved down to the South low roof & finished laying down the foil insulation & screwing down the roof metal.
/ WKY Horse Barn
Getting the foil insulation nailed down in the breeze was definitely a 2-person job. 2 others on the ground passed up the sheets
/ WKY Horse Barn
The end of the day the wind died down & we got back up on the South high roof & 2 widths of insulation down along with 3 sheets of roofing. Here’s a view of the South side. What a great feeling @ the end of the day to have been able to get 32 sheets of roofing down. Now we’re counting down the last 13! That’ll be great when we get it all down.
/ WKY Horse Barn
Here’s a view of the North side w/all the roof DONE! Next on this side will be the trim for the short high siding along with the high siding.
/ WKY Horse Barn
Here’s a close up of the service door & framing from the inside of the soon to be tack room. The electric sub panel will be to the right of the door. This door is pretty much in line with the stairs coming off the back porch of the house.
/ WKY Horse Barn
Well it's been a while since I posted, bad weather & other chores have somewhat interrupted barn progress. Here's a photo of how I "tweeked" a bowed beam so that the door track would be straight.
/ WKY Horse Barn
Here's a close up of the big rooling door track, cover & sheet metal fabricated end caps I made to keep the weather off the exposed end of the 2x4 holding the track.
/ WKY Horse Barn
Here's shot of the door jamb flashing. Had to cut & bent it a bit around my beam corbels.
/ WKY Horse Barn
Here we are starting the insulation on the end wall prior to hanging the sheeting.
/ WKY Horse Barn
Here's a long range view of the new barn, house & shop (left to right). The new barn location will be much handier than the old one that is behind where I took the photo.
