What battery charger do you use?
/ What battery charger do you use? #61
I have an AGM battery in my Hustler Raptor X lawn mower that needs charging. I've been told that a normal battery charger (Schumacher SC-600A) can't be used. What battery charger are you using for AGM batteries? Also, the battery in my Kioti DK4510 is getting weak, and I'm thinking of replacing it with an AGM battery. Any suggestions and/or issues?
The only AGM battery I might have would be inside my computer Universal Power Supplies, and by definition those units contain the charger. But, the last 10 amp battery charger I bought - from Harbor Freight about five years ago - has a switch on the front to go from "standard" to "AGM."
/ What battery charger do you use? #65
I use a Schumacher SC1359. It has an AGM mode. Has been working great for a couple of years.
www.schumacherelectric.com/products/sc1359-15a-6v-12v-fully-automatic-battery-charger/?srsltid=AfmBOopLYfoULdAUFeTr7ZEsjDc4PUgUYKmKTb8oa3i2OcuL8-pwOQCc
/ What battery charger do you use? #67
/ What battery charger do you use? #68
I have had two BatteryMinders fail, one that flatted a battery out.
I have a few Battery Tenders that are doing well, one must be 20 years old.
/ What battery charger do you use? #69
I have a Battery Tender™ which puts out a steady 16v no matter what (yes, it is broken and long out of its 10 year warranty). Have a couple others which do the right thing. All my new battery maintainers are NOCO.
/ What battery charger do you use? #70
Another point to make is that Ford manages one’s vehicle battery different if AGM vs lead-acid. The setting is in Ford’s service computer and also accessible by the public with Forscan.
/ What battery charger do you use? #72
NOCO from Walmart or Amazon. Super solid and reliable.
/ What battery charger do you use? #74
Hey Airbiscuit how’s that 100 amp jump start working for ya? I find it difficult to believe since that thing is so small. But a hundred amps ain’t much compared to a 600 amp cca battery
What you have to understand is a battery is a chemical reaction, it will attempt to justify load (amperage output) no matter what it is till it implodes....
/ What battery charger do you use? #75
I have one of the CTEK chargers, which has the correct charging profile for AGM batteries and conventional ones. It automatically transitions to a maintainer once a battery is charged. Supposedly, it also has the ability to work miracles with discharged/neglected batteries. Overall, it seems to work well, so I'm happy.
For faster charging of a discharged battery, I'll hook up my several decades old Schumacher charger that keeps on tickin'.
/ What battery charger do you use? #78
Bummer. I probably have at least 10 BatteryMINDers by now, the oldest ones from the late '90s. Never an issue...so far.
Recently had a small NOCO kill a good battery, though.
I don't have near 10, but I do have three BatteryMinders and haven't had any issues yet either!
/ What battery charger do you use? #79
NOCO Genius10 Multi-stage charging, desulfator, lithium/AGM/flooded modes, waterproof, auto float mode for maintenance
/ What battery charger do you use? #80
Each of my 5 trailers has a battery, the only one with a solar charger is the fuel trailer. Some sit for an extended time without being used and are not near a plug for a charger. I just bought the Dewalt 4-amp charger/power pack that uses the 20V Dewalt batteries. Plan is to put it on a trailer and let it charge up. The charger indicates when it is a full charge. It is not a jump starter, just a trickle charger. No more dragging the big charger around or stretching extension cords.
MCCORMICK T110 MAX TRACTOR (A60430)
MCCORMICK T110 MAX...
UNUSED FUTURE QSJ HYD MINI SWEEPER (A60432)
UNUSED FUTURE QSJ...
UNUSED 1RGC40 HIGH END MINI GOLF CART (A60432)
UNUSED 1RGC40 HIGH...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
UNUSED KJ - K1912 - 20' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ - K1912...
2017 Nissan Altima 4 door (A61306)
2017 Nissan Altima...
