What battery charger do you use?
/ What battery charger do you use? #1
4x4moses
Member
Laurel, MS
Kioti DK4510
I have an AGM battery in my Hustler Raptor X lawn mower that needs charging. I've been told that a normal battery charger (Schumacher SC-600A) can't be used. What battery charger are you using for AGM batteries? Also, the battery in my Kioti DK4510 is getting weak, and I'm thinking of replacing it with an AGM battery. Any suggestions and/or issues?
/ What battery charger do you use? #3
This does it just fine for AGM. And its not mentioned, yet it does lithium too on the 2Amp charge setting!
/ What battery charger do you use? #4
Old school, transformer based (got to be 40 years old) .... Pushes battery up to 16.5 volts (long float charge) .... Use it on my AGMs and Lead Acids.... And for electrolysis rust removing.... New microprocessor chargers sometimes won't start a charge if battery is to low, and you have to jump start charger with good battery... Owners manual that comes with ODYSEEY AGM batteries state not to go over 15 volt or the will "off gas"... Suggest you look up brand and size/type of your battery and see if there are charging instructions or precautions, no to just go with what "someone" tells you....
See starting at page 10 for charging instructions for ODYSEEY AGMS...
/ What battery charger do you use? #5
I use Battery Minders for golf cart batteries (48v), tractor, mowers, and vehicles. I have an 8 amp Battery Minder for quicker charging, and multiple 2 amp maintainers.
They are a little pricey, particularly for the 12v 8 amp and 48v 3 amp chargers.
/ What battery charger do you use? #6
Big John Deere on wheels. Thing is a beast. Never fails, even on double & triple batteries.
/ What battery charger do you use? #7
Like everyone says about any kind will work. But some of them could be damaging also, and short life that agm battery. Cells being sealed inside makes it difficult to dissipate heat r charges from the charging process. So agm batteries should be charged at a slower rate than conventional lead acid type batteries. I get good service from agm batteries and so far no leakage or corrosion at the terminals. Good luck with you charge sir.
/ What battery charger do you use? #9
Ditto on the NOCO chargers. Very compact and foolproof. You can let anyone use it and not worry about connecting wrong. Simple display. Handy little bag to carry everything if you like.
The battery clamps are very well made and clamp on securely. I have a NOCO 10 and one of their Boost/Jump Starters too. (It doubles as a pretty handy power supply for charging phones and tablets and basically anything that uses USB to charge.)
Amazon will have it to you next day probably.
No digital display showing voltage, so I think everyone also needs a multi-meter so they can check and troubleshoot in addition to their charger.
/ What battery charger do you use? #10
AGM batteries have the same charging profile as flooded lead acid (FLA) batteries so any charger will work. AGM batteries differ from FLA mostly in that glass mats (the GM in AGM) are sandwiched between the lead plates which prevent the plates from shorting against each other if conditions cause the plates to warp. AGM also is vented through a pressure release mechanism (VRLA), rather than the open vent FLA employs.
To answer your question, Victor chargers stand above the crowd in my opinion. I have 9 batteries of all types (FLA, AGM, LiFePO4) on charger tenders at this moment. The Bluetooth feature displays SOC of any/all batteries at a glance on a smart device.
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
2023 SNORKEL A46JRT ROUGH TERRAIN BOOM LIFT (A59823)
2023 SNORKEL...
SKLP SK-HJ6 40' 6 Section Storage Shelves (A60463)
SKLP SK-HJ6 40' 6...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
