What battery charger do you use?
   / What battery charger do you use? #61
I have an AGM battery in my Hustler Raptor X lawn mower that needs charging. I've been told that a normal battery charger (Schumacher SC-600A) can't be used. What battery charger are you using for AGM batteries? Also, the battery in my Kioti DK4510 is getting weak, and I'm thinking of replacing it with an AGM battery. Any suggestions and/or issues?
The only AGM battery I might have would be inside my computer Universal Power Supplies, and by definition those units contain the charger. But, the last 10 amp battery charger I bought - from Harbor Freight about five years ago - has a switch on the front to go from "standard" to "AGM."
   / What battery charger do you use? #65
I use a Schumacher SC1359. It has an AGM mode. Has been working great for a couple of years.
www.schumacherelectric.com/products/sc1359-15a-6v-12v-fully-automatic-battery-charger/?srsltid=AfmBOopLYfoULdAUFeTr7ZEsjDc4PUgUYKmKTb8oa3i2OcuL8-pwOQCc
   / What battery charger do you use? #67
   / What battery charger do you use? #68
I have had two BatteryMinders fail, one that flatted a battery out.
I have a few Battery Tenders that are doing well, one must be 20 years old.
   / What battery charger do you use? #69
I have a Battery Tender™ which puts out a steady 16v no matter what (yes, it is broken and long out of its 10 year warranty). Have a couple others which do the right thing. All my new battery maintainers are NOCO.
   / What battery charger do you use? #70
Another point to make is that Ford manages one’s vehicle battery different if AGM vs lead-acid. The setting is in Ford’s service computer and also accessible by the public with Forscan.
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A56858)
2008 Ford E-350...
Butterfly Artwork (A55758)
Butterfly Artwork...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2008 BOBCAT 323 J MINI EXCAVATOR (A57880)
2008 BOBCAT 323 J...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
